[petsc-dev] private branch of petsc-dev (fwd)
Fri Feb 8 19:36:59 CST 2013
   My understanding is that git branches are ideal for this.
   Barry
On Feb 8, 2013, at 7:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Barry/Jed/Sean,
> Should we have a recommended method of handling 'private branch' for
> petsc developemnt?
> thanks,
> Satish
> ---------- Forwarded message ----------
> Date: Fri, 8 Feb 2013 16:24:46 -0600 (CST)
> From: Satish Balay <balay at mcs.anl.gov>
> To: Hong Zhang <hzhang at mcs.anl.gov>
> Subject: Re: private branch of petsc-dev
> There might be different ways of doing it with different tradeoffs
> with each method.
> Perhaps you might have to use bookmarks or something. I don't know
> enough about this.
> One way do this is [similar to the way we do petsc-dev/petsc-3.3 split
> work]:
> - have a separate petsc-dev clone somehwere as say petsc-dev-qlp.
> - you and Terrya will have a clone of this petsc-dev-qlp repo locally
> where new code gets added.
> - pull/merge from current petsc-dev to petsc-dev-qlp regularly [if
> this development has to be in sync with petsc-dev]
> - Only when everything is done/ready push from petsc-dev-qlp clone to
>  petsc-dev
> The drawback here is - the history of this work would be messy [with
> all the merges etc..]
> The other way is:
> - *never* sync with petsc-dev until this work is done.
> - merge with petsc-dev when its done. [either merge - or rebase it over]
> The *never* sync with petsc-dev is a drawback for this.
> Perhaps Sean/Jed will have better responses. [wrt bookmarks]
> Satish
> On Fri, 8 Feb 2013, Hong Zhang wrote:
>> Satish,
>> How to create a private branch of petsc-dev for me and
>> Sou-Cheng (Terrya) Choi to develop new KSP miners-qlp?
>> Should I use 'hg branch'?
>> I tested, but got trouble on how to merge the branch back
>> to the default repo.
>> Hong
