[petsc-dev] ugliness due to missing lapack routines
Thu Feb 7 22:09:13 CST 2013
On Thu, Feb 7, 2013 at 7:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Yup, absolutely and not a problem since we write the implementations and
> only the interface is generated. Surely we would not write some generator
> that is so stupid that it would generate the same thing twice and then barf
> because it got confused? We have slightly higher standards than Babel.
Okay, but now the generator needs a global view and/or an understanding of
module dependencies. How will you express those dependencies? Here's a
compiler guy talking about how to design a module system for C.
http://llvm.org/devmtg/2012-11/Gregor-Modules.pdf
> > No, you're just changing the behavior of the code by annotating using
> comments. I.e., extending the language. It's not plain C because the
> "comments" are semantically significant and not even optional.
>    I knew you would say that. Using comments would only be a temporary
> thing until the tools knew a bit about the class structure and could do
> everything automatically.
But not "automatically" in C because these semantics are not directly
expressible in C. Presumably you're going to add keywords/syntax to
communicate that structure. And now you're making a new programming
language.
> > HOW does it "understand" the semantics you are writing down? Is it
> through more annotation that you're going to put in the comments? Or magic
> names and a piece of code in the preprocessor that recognizes that name and
> pattern?
>    No, based on dependencies it can figure out the types of the internal
> variables from the the type change to the argument thus doesn't need you to
> "mark" the variables with some "type" crap name.
1. Is your language going to have type inference too?
2. Somewhere we have to decide between static and dynamic typing. Will your
language have a JIT?
>    Yes and that is part of the problem. We are dependent on these
> non-machine-manipulatable constructs in our code (yes, my fault). Hacks, if
> you will.
Sure, but what do you replace them with? Comments instructing the
preprocessor to perform the equivalent of macro expansion? How is that
machine-manipulatable? The manipulator needs to understand your comments to
do anything.
>    Regardless, we are using code generation today. Why don't we at least
> do it honestly and have the generators separate from the data they use to
> do the generation and the location where the generated code goes? Now it is
> all in the same damn file!
I don't think that distributing the logic between more languages/files is
better in any way.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130207/d37b02f1/attachment.html>
