[petsc-dev] ugliness due to missing lapack routines
Thu Feb 7 17:18:51 CST 2013
On Thu, Feb 7, 2013 at 6:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 7, 2013, at 4:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > I think we have all the facts on the high level discussion. Concrete
> proposals to be voted on:
> >   1) Get rid of all function-like CPP things
>     Right now we can get rid of any CPP macro functions that can be
> trivially converted to C functions. The ones we cannot get rid of are ones
> that take "types" or block sizes as arguments. (these are used as code
> generation macros; generating a chunk of C code for each type).
We should work on eliminating those first. This is a good test of how
usable the code generation would be.
> >   2) Get rid of (Matt says) innocuous CPP things, like CHKERRQ
>    We don't need to get rid of them. These can all be swept out by one
> massive automated regular expression sed type operation when the time is
> right. In fact I should just write that now for experimentation purposes.
Yes.
> >   3) Generate full functions for missing LAPACK stuff, which will
> probably necessitate changing petscblaslapack.h
>     I don't see that this should require any change to petscblaslapack.h
> (though we may want to change petscblaslapack.h at some point for other
> reasons)
Okay, I will try and do this in a week.
> 4)
> #undef __FUNC__
> #define __FUNC__
>    Can all be swept out automatically at the right time.
Yes.
> 5)
> #define KSPGMRES "gmres"
We had this argument. The typedef behaves in a weird was with 'const'.
> 6)
> #if defined(PETSC_HAVE_SOMEINCLUDE)
> #include <someinclude.h>
>    I was thinking we could auto generate empty someinclude.h for these
> (putting in $PETSC_ARCH/include) Cheesy but ?
Hmm, that seems fragile. I would rather generate the header lists.
    Matt
7) Some other uses of CPP
>   Barry
> >     Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130207/7d87ea28/attachment.html>
