[petsc-dev] ugliness due to missing lapack routines
Thu Feb 7 16:07:15 CST 2013
On Thu, Feb 7, 2013 at 3:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Why would it not be? Your editor is not capable of ever displaying more
> than one buffer ever?
Now I'll have two versions of the "same file". I could probably even script
Emacs to handle this better than it normally does (like a keybinding to
flip between original and preprocessed), but everyone that interacted with
the code would have to do the same. Would we use this method in examples or
would they all contain CHKERRQ stuff?
It would be a disaster to require everyone to run our preprocessor just to
compile their code. It is tantamount to creating another language.
>    If you want to think in terms of revision control systems and working
> directories then when using the debugger your "smudged" version of the code
> has all the "generated" (CHKERRQ….)
> stuff displayed. How it could work: while using the debugger you realize a
> bug exists, you "fix" the bug in the "smudged" version in your working
> directory based on what you see in the debugger, run the compile, load the
> new executable in the debugger, verify your fix works and then "add" in git
> your smudged (now fixed) code into the "index" at which point it is
> "desmudged" back into the standard form. You can then commit and push.
Wait, which version do we edit when we don't have a bug?
> Note that this does not even require some GUI development system and is
> similar to our current work flow. The only "new" concept is the concept of
> having various "smudged" versions of the code in the working directory.
Yeah, I think that having multiple versions will be much more difficult to
work with than you seem to think.
> > I agree that CPP is a crappy code generator. In lieu of hygienic macros,
> we either need to use a separate source language
>    Why? C is a great language, we can just generate from C.
You must mean C plus some yet-to-be-defined templating system. I've never
seen such a thing done well.
>   Generating code on a case by case ad hoc basis will result in a mess.
> Doing it in a systematic way using a good representation need not.
If you really believe this, start proposing semantics. I think it will be
very difficult to avert a disaster and I don't think it could possibly
offer that much value.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130207/78d3d80e/attachment.html>
