[petsc-dev] Fwd: [petsc-maint #149715] Making a PetSc Roll and Rocks Module
Mon Feb 4 23:05:27 CST 2013
  Satish,
   It looks like the module name should simply be PETSC_VERSION
    Could you please make this change? (modules don't make much sense for people self-installs with PETSC_ARCH anyways so no reason to attach PETSC_ARCH to name)
    Then the installer person moves the module file (and changes the name if they like) after installing.
    Also, check what is inside a PETSc module file at Nersc to make sure we are capturing everything we should capture.
   Thanks
    Barry
On Feb 4, 2013, at 10:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 4 Feb 2013, Barry Smith wrote:
>>> If PETSC_ARCH is not specified by user - configure creates one and
>>> uses it. It looks ugly for prefix build - but then - making one build
>>> better means compromising somewere else.
>>> options:
>>> - don't use PETSC_ARCH in the module file name [but then rely on users
>>> to rename it when they copy it over to the appropriate location.
>>> - don't use PETSC_ARCH in module name for only prefix installs.
>>> But this becomes inconsistant.
>>> - provide a configure option for users to specify a name for this modulefile.
>>> [defalt always uses PETSC_ARCH]
>>> - [others?]
>>   What about ${PETSC_VERSION}${PETSC_ARCH}?
>> The user has to rename/move the module files for prefix installs so maybe we don't need to give it any particular name, just petsc-module?
>> Yes it is ugly without the hyphen but at least without PETSC_ARCH it is consistent.
>> The concept of module file seems silly with PETSC_DIR/PETSC_ARCH installs, should we  even make them in that case?
>> BTW: Can you check what the PETSc module files look like at Nersc?
> balay at hopper05:~> module avail petsc
> ---------------------------------------- /opt/cray/modulefiles -----------------------------------------
> petsc/3.1.04                  petsc/3.3.00                  petsc-complex/3.2.02(default)
> petsc/3.2.02(default)         petsc-complex/3.1.04          petsc-complex/3.3.00
> ------------------------------------------- /opt/modulefiles -------------------------------------------
> --------------------------------- /usr/common/acts/Modules/modulefiles ---------------------------------
> petsc/3.1                 petsc/3.1_g               petsc/3.2_g_complex
> petsc/3.1-opkgs_O         petsc/3.1_g_c++           petsc/3.3
> petsc/3.1-opkgs_O_c++     petsc/3.1_g_complex       petsc/3.3_O
> petsc/3.1-opkgs_O_complex petsc/3.2                 petsc/3.3_O_c++
> petsc/3.1-opkgs_g         petsc/3.2_O               petsc/3.3_O_complex
> petsc/3.1-opkgs_g_c++     petsc/3.2_O_c++           petsc/3.3_O_tau
> petsc/3.1-opkgs_g_complex petsc/3.2_O_complex       petsc/3.3_g
> petsc/3.1_O               petsc/3.2_O_tau           petsc/3.3_g_c++
> petsc/3.1_O_c++           petsc/3.2_g               petsc/3.3_g_complex
> petsc/3.1_O_complex       petsc/3.2_g_c++
>>> BTW: I'm not usre if 'lib' is the correct location to stash module/pkgconfig files.
>>> Autoconf install might provide options like --prefix --module-prefix --pkgconfig-prefix?
>> Barrys-MacBook-Pro:petsc-dev barrysmith$ ls /usr/lib/pkgconfig/
>> apr-1.pc         apr-util-1.pc    libcrypto.pc     libedit.pc       libiodbc.pc      libpcre.pc       libpcreposix.pc  libssl.pc        openssl.pc
>> Barrys-MacBook-Pro:petsc-dev barrysmith$ ls /usr/local/lib/pkgconfig/
>> PETSc.pc        libpcre.pc      libpcrecpp.pc   libpcreposix.pc libpng.pc       libpng15.pc     libtiff-4.pc    tesseract.pc    valgrind.pc
>> bsmith at login2:~$ ls /usr/lib/pkgconfig/
>> apr-1.pc       dbus-python.pc  fontutil.pc  glew.pc		   ibus-table.pc       mpich2-c.pc    nautilus-sendto.pc  printproto.pc		  python2.pc	 sawfish.pc
>> apr-util-1.pc  fftw3f.pc       fuse.pc	    gnome-system-tools.pc  libquvi-scripts.pc  mpich2-cxx.pc  netcdf.pc		  pygtksourceview-2.0.pc  python-dbg.pc  scrnsaverproto.pc
>> cln.pc	       fftw3l.pc       ginac.pc     gsl.pc		   libR.pc	       mpich2-f77.pc  notify-python.pc	  python-2.7-dbg.pc	  python.pc	 valgrind.pc
>> cppunit.pc     fftw3.pc        ginn.pc	    gts.pc		   mcabber.pc	       mpich2-f90.pc  pm-utils.pc	  python-2.7.pc		  rep-gtk.pc	 xorg-wacom.pc
> My machine has it at '/usr/
> asterix:/home/balay>ls /usr/share/pkgconfig
> bash-completion.pc  glproto.pc              renderproto.pc       xextproto.pc
> bigreqsproto.pc     gnome-icon-theme.pc     resourceproto.pc     xf86bigfontproto.pc
> compositeproto.pc   gnome-keybindings.pc    scrnsaverproto.pc    xf86dgaproto.pc
> damageproto.pc      gnome-video-effects.pc  shared-mime-info.pc  xf86driproto.pc
> dmxproto.pc         gtk-doc.pc              spice-protocol.pc    xf86miscproto.pc
> dri2proto.pc        inputproto.pc           systemd.pc           xf86vidmodeproto.pc
> emacs.pc            kbproto.pc              udev.pc              xineramaproto.pc
> evieproto.pc        libquvi-scripts.pc      usbutils.pc          xproto.pc
> fixesproto.pc       randrproto.pc           videoproto.pc        xproxymngproto.pc
> fontsproto.pc       recordproto.pc          xcmiscproto.pc
> Satish
