[petsc-dev] Registration implicitly collective on COMM_WORLD
Mon Feb 4 21:22:54 CST 2013
On Sat, Feb 2, 2013 at 3:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Yeah I noticed this problem but didn't want to deal with it when I
> changed the code.
So if we believe the documentation of PetscFunctionListAdd,
XXInitializePackage() is effectively collective on COMM_WORLD (though not
documented as such). This means that if
!defined(PETSC_USE_DYNAMIC_LIBRARIES), the following could deadlock:
if (!rank) {
  VecCreate(PETSC_COMM_SELF,....);
which would be awfully bad behavior. In reality, PetscFunctionListAdd()
does not reference comm at all. Why did you add the comm argument?
"Consistency"?
Whatever the "next" documentation system is, it should be taught to trace
the "collective" attribute and complain if a "Not Collective" function
calls a Collective function with an argument other than COMM_SELF.
>     Yes we should remove the "Formally Collective", I was drinking that
> week :-)
>    Barry
> On Feb 2, 2013, at 2:54 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > In [1], PetscFunctionListAdd became implicitly collective on COMM_WORLD,
> but the all the XXRegisterDynamic() say "Not collective". These all have to
> be updated if this is the case, but I'm not sure it's even a good thing.
> What if we have a big multi-domain simulation in which we initialize each
> of the components on their own subcomm. Those sub-components would not be
> allowed to register methods (or load plugins) that they might use because
> registration was implicitly more global.
> > The comm is used by PetscLs and others. This is important because file
> systems are terrible at independent access. (Same for loading shared
> libraries; it's potentially much easier to do it by broadcasting the
> library, though portability is tricky.)
> > Anyway, it would be really bad to PetscDLLibraryAppend() on a subcomm
> and have the registration function in the shared lib call
> PCRegisterDynamic() that promotes itself to COMM_WORLD.
> > Maybe we need to pass an explicit comm to all the registration functions.
> > [1]
> https://bitbucket.org/petsc/petsc-dev/commits/07f9e01e040feeb4162253a60ca63556436f4135
> > What does "Formally collective" mean anyway? Either it's always safe to
> call independently, it's "Logically collective" so that there is no
> performance impact, but it still needs to be collective to have consistent
> state, or it's Not Collective. This falls under Not Collective because it
> can deadlock if you call it independently.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130204/e12a480b/attachment.html>
