[petsc-dev] Pushing non-working code
Karl Rupp rupp at mcs.anl.gov
Sun Feb 3 11:32:19 CST 2013
On 02/03/2013 11:25 AM, Sean Farley wrote:
> On Sun, Feb 3, 2013 at 11:17 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Feb 3, 2013 at 12:16 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Sun, Feb 3, 2013 at 11:11 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>>> Can you quantify your productivity gains that come from pushing
>>>>> checkpoints instead of waiting for a semantically meaningful point to merge
>>>>> and push?
>>>> I can quantify the losses from the changed you propose, which is all I
>>>> need to do.
>>> Do share.
>> Its more work for me. Clearly you are asking me to do something I do not
>> currently do. A loss.
>>>> There are no "gains" from a baseline. This is
>>>> a point I have made multiple times. Changes must be justified.
>>> I provided a long list of justifications that you have not responded to.
>>> There is a great deal of empirical evidence to back my claims.
>> I have responded to each and every point carefully. You need to listen.
> I have been following this conversation closely but have not seen you
> respond to any of the points on code review, new bugs, etc. I have
> seen you complain that you don't want to change your habits, though.
+1 for Sean. I'm tired of carefully writing down the points I'm trying
to make, carefully (re-)reading through what I've written, and then just
to get a generic 'how does this relate to XYZ'-type of answer without
really addressing anything I've raised.
Best regards,
Karli
