[petsc-dev] Pushing non-working code
Hong Zhang hzhang at mcs.anl.gov
Sat Feb 2 17:17:24 CST 2013
I agree with Matt on this issue.
'petsc-dev' means 'dev', that a developer should be able to push on-going work
after he/she does local tests and is willing to fix the warning/bug as soon as
the problems appear. Personally, I am unable to write a bug/waring free code,
not matter how much effort and time to put into it.
Hong
On Sat, Feb 2, 2013 at 4:56 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi guys,
>>     They issue warnings and the code can't possibly execute correctly.
>>     Just don't push it (or push it somewhere else) until it's been
>>     cleaned up to the point where it's not wasting our time to review.
>> I would love it if people never pushed code with any bugs. This is
>> possible, just not efficient. All changes to
>> workflow should be evaluated on this basis. For this particular change,
>>    1) It does not break the build
>>    2) Its a new feature, so does not break tests except the ones its
>> supposed to
>> I do think warnings are annoying and people should endeavor to push code
>> with no
>> warnings, but making this a requirement takes away flexibility while
>> providing nothing
>> I can see except lack of Jed Annoyance. The claim that you are code
>> reviewing this
>> push is false on its face.
> I support Jed's point at this place. Staying 'close to stability' has the
> additional benefit of finding bugs earlier and being able to go for shorter
> release cycles. Jed only requests a higher discipline when committing code.
> It usually takes a fraction of the time to fix warnings immediately rather
> than keeping them around.
>>     Related: I would like to start tweaking our workflow to make
>>     petsc-dev more consistently stable, so that more applications can
>>     work with it instead of needing to wait for a release. Having people
>>     pushing code that doesn't work, isn't tested, and obviously wouldn't
>>     pass review is not good for stability.
> That's why I want to tackle improved test system output. Once we get used to
> an 'all green' test report in the morning, motivation for keeping this state
> goes up. Also, I think that it improves the discipline in adding tests for
> things not yet covered by the test system. That may sound naive, but it is
> my personal experience with other software.
> Best regards,
> Karli
