[petsc-dev] Use of PETSC_DEFAULT in Chaco interface
Sat Feb 2 15:37:09 CST 2013
On Sat, Feb 2, 2013 at 3:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Feb 2, 2013 at 3:27 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> This is probably my fault. I think PETSC_DEFAULT is not necessary here.
>> Just initialize chaco->eigen_method to 0 (Chaco's default). Can you fix it?
> Thanks, I'll do that.
https://bitbucket.org/petsc/petsc-dev/commits/bc26e3068c95a85d1976ab5a488994d3022db817
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130202/97bbf5ad/attachment.html>
