[petsc-dev] Registration implicitly collective on COMM_WORLD
Sat Feb 2 14:54:36 CST 2013
In [1], PetscFunctionListAdd became implicitly collective on COMM_WORLD,
but the all the XXRegisterDynamic() say "Not collective". These all have to
be updated if this is the case, but I'm not sure it's even a good thing.
What if we have a big multi-domain simulation in which we initialize each
of the components on their own subcomm. Those sub-components would not be
allowed to register methods (or load plugins) that they might use because
registration was implicitly more global.
The comm is used by PetscLs and others. This is important because file
systems are terrible at independent access. (Same for loading shared
libraries; it's potentially much easier to do it by broadcasting the
library, though portability is tricky.)
Anyway, it would be really bad to PetscDLLibraryAppend() on a subcomm and
have the registration function in the shared lib call PCRegisterDynamic()
that promotes itself to COMM_WORLD.
Maybe we need to pass an explicit comm to all the registration functions.
[1]
https://bitbucket.org/petsc/petsc-dev/commits/07f9e01e040feeb4162253a60ca63556436f4135
What does "Formally collective" mean anyway? Either it's always safe to
call independently, it's "Logically collective" so that there is no
performance impact, but it still needs to be collective to have consistent
state, or it's Not Collective. This falls under Not Collective because it
can deadlock if you call it independently.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130202/b02d6f2c/attachment.html>
