[petsc-dev] patch for BiCG on GPUs (reworked).
Fri Feb 1 18:41:47 CST 2013
That's gonna suck. Karl, can you apply his patch to the old code, run
uncrustify on it, then send out the diff (which should apply cleanly to
head).
On Feb 1, 2013 6:32 PM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
> Hi Paul,
> I just uncrustified src/mat/impls/aij/* and pushed it to petsc-dev. Could
> you please re-generate your patch based on the latest commit?
> Thanks and best regards,
> Karli
> On 02/01/2013 06:11 PM, Paul Mullowney wrote:
>> Hi,
>> Here's a reworked patch for running BiCG on GPUs (with ILU(0)
>> preconditioners) on GPUs for the aijcusparse.cu class. I fixed the
>> comments from the previous emails on this patch. In particular, I added
>> (1) VecConjugate implementation in veccusp.cu with the correct method
>> for getting the device ptr (VecCUSPGetArrayReadWrite()).
>> (2) Various methods in aijcusparse.cu for building the transpose
>> matrices for MatSolveTranspose* methods. The implementation of the
>> solves is done under the hood in the txpetscgpu library. A protection
>> was added to ensure the matrix generation routines are only called once.
>> (3) I fixed the uninitialized compiler warning when building in double
>> complex. This required a slight fix in VecCUSPGetArrayWrite().
>> (4) Small Style fixes.
>> I wasn't clear to me how to break this up patch into a small
>> organizational patch and then a large implementation patch. If you have
>> suggestions on what corresponds to organization and what corresponds to
>> implementation, I can try to do that in subsequent patches.
>> Everything builds and runs fine on my end.
>> Thanks,
>> -Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130201/61b4acce/attachment.html>
