[petsc-dev] patch for BiCG on GPUs (reworked).
Paul Mullowney paulm at txcorp.com
Fri Feb 1 18:11:12 CST 2013
Here's a reworked patch for running BiCG on GPUs (with ILU(0)
preconditioners) on GPUs for the aijcusparse.cu class. I fixed the
comments from the previous emails on this patch. In particular, I added
(1) VecConjugate implementation in veccusp.cu with the correct method
for getting the device ptr (VecCUSPGetArrayReadWrite()).
(2) Various methods in aijcusparse.cu for building the transpose
matrices for MatSolveTranspose* methods. The implementation of the
solves is done under the hood in the txpetscgpu library. A protection
was added to ensure the matrix generation routines are only called once.
(3) I fixed the uninitialized compiler warning when building in double
complex. This required a slight fix in VecCUSPGetArrayWrite().
(4) Small Style fixes.
I wasn't clear to me how to break this up patch into a small
organizational patch and then a large implementation patch. If you have
suggestions on what corresponds to organization and what corresponds to
implementation, I can try to do that in subsequent patches.
Everything builds and runs fine on my end.
-Paul
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130201/d33f99b3/attachment.ksh>
