[petsc-dev] git : list branches started off maint - but not yet merged back
Sat Aug 31 10:22:28 CDT 2013
On Fri, 30 Aug 2013, Jed Brown wrote:
> > Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed Jul 17 07:53:11 2013 -0500
> > 506c33d Configure: Fixed logic when using --with-package-lib when the package has no includes
> Looks fine to me, but will wait for Matt.
For stuff in next [that started from maint - but not yet in master?] -
I see the following. Should they simmer for some more time in next and
then master?
Candidate for maint: refs/remotes/origin/barry/hyprewithprinterrors Sat Aug 24 09:25:39 2013 -0500
69ccb71 debug version of downloaded hypre compiled with --with-print-errors to help debugging
Candidate for maint: refs/remotes/origin/jed/avoid-getpwuid Fri Aug 30 18:10:37 2013 -0700
6c8deb0 Sys: fix PetscGetFullPath expansion of ~ and ~user, ensure NULL termination
45082d6 Sys: avoid getpwuid in file path routines
311ae19 Sys: add failing test expanding ~/file-name and ~user/file-name
Candidate for maint: refs/remotes/origin/prbrune/snes-jacobiancolormgfix Thu Aug 29 14:18:01 2013 -0500
f74a8d1 Add a test example for TS + MG + MatFDColoring
c89319d Fixed SNESComputeJacobianDefaultColor() in the case of multilevel PC
Satish
