[petsc-dev] git : list branches started off maint - but not yet merged back
Thu Aug 29 21:54:46 CDT 2013
I merged all mine to master. They are done.
   Matt
On Thu, Aug 29, 2013 at 9:51 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 29 Aug 2013, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > >> candidate-branches () {
> > >>   merged=$1
> > >>   dest=$2
> > > what are the arguments here?. Looks a bit complex - so will leave this
> to you.. :)
> > Just paste it into your shell, or put it in .bashrc.
> > $ candidate-branches master maint
> It works by checking whether the "merge base" of the branch with
> 'master' (before it was merged to 'master') is actually part of 'maint'.
> You mean - this is looking for all branches that started off a 'maint'
> commit [which is currently in master] - and also its head is merged
> into master aswell?
> BTW: I get some errors:
> fatal: Not a valid object name ~1
> usage: git merge-base [-a|--all] <commit> <commit>...
>    or: git merge-base [-a|--all] --octopus <commit>...
>    or: git merge-base --independent <commit>...
>    or: git merge-base --is-ancestor <commit> <commit>
>     -a, --all             output all common ancestors
>     --octopus             find ancestors for a single n-way merge
>     --independent         list revs not reachable from others
>     --is-ancestor         is the first one ancestor of the other?
> Candidate for maint: refs/remotes/origin/barry/petscdatatypefromstring Fri
> Aug 23 21:12:13 2013 -0500
> Candidate for maint: refs/remotes/origin/jed/fix-gamg-coarse Wed May 29
> 22:29:42 2013 -0500
> refs/remotes/origin/jed/fix-viewer-ascii-tab-whitespace Wed Jun 19 09:19:55
> 2013 +0200
> Candidate for maint: refs/remotes/origin/jed/is-view-from-options Sun Aug
> 25 01:10:01 2013 -0500
> Candidate for maint: refs/remotes/origin/jed/mat-factor-shift Sat Jun 1
> 12:23:49 2013 -0500
> Candidate for maint: refs/remotes/origin/jed/pcmg-residual-underscore Wed
> Jun 26 16:22:39 2013 -0500
> Candidate for maint: refs/remotes/origin/karlrupp/feature-viennacl Mon Jun
> 10 16:44:57 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed
> Jul 17 07:53:11 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/fix-mat-chop Wed May 29
> 06:46:26 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/reordering Tue Aug 27
> 22:39:10 2013 -0500
> Candidate for maint: refs/remotes/origin/prbrune/pcgamg-classical Thu Jun
> 27 12:30:19 2013 -0500
> Candidate for maint: refs/remotes/origin/prbrune/snes-npcjacobianlagging
> Tue May 14 09:50:15 2013 -0500
> Candidate for maint: refs/remotes/origin/toby/ksp-dgmres-view Tue Jun 4
> 06:20:21 2013 -0500
> Candidate for maint: refs/remotes/origin/toby/pcfactorgetlevels Fri Jun 7
> 14:20:33 2013 -0500
> Candidate for maint: refs/remotes/origin/toby/pcgamg-rebuild-coarse Wed
> Jul 24 16:12:18 2013 -0500
> balay at asterix /home/balay/petsc.clone (master)
> > Candidate for maint: refs/remotes/origin/balay/fix-deadlock-on-bgq Wed
> Aug 28 11:57:58 2013 -0500
> > Candidate for maint: refs/remotes/origin/balay/fix-scalapack-mpiinc Thu
> Jul 4 14:31:22 2013 -0500
> These two are already merged into maint. Are they listed because you
> haven't done a 'git fetch' in a while? Also perhaps its better to use
> 'candidate-branches origin/master origin/maint'?
> Fri Aug 23 21:12:13 2013 -0500
> 22:29:42 2013 -0500
> 2013 +0200
> Aug 25 01:10:01 2013 -0500
> 12:23:49 2013 -0500
> Wed Jun 26 16:22:39 2013 -0500
> Jun 10 16:44:57 2013 -0500
> Wed Jul 17 07:53:11 2013 -0500
> 06:46:26 2013 -0500
> 22:39:10 2013 -0500
> Jun 27 12:30:19 2013 -0500
> 06:20:21 2013 -0500
> 7 14:20:33 2013 -0500
> This is a big list. Perhaps everyone can comment if they should be merged
> into maint..
> [added in a couple more lines to get the list of oustanding commits in
> that branch - I see 'karlrupp/feature-viennacl' and a few others are
> false positives..]
>     git log --oneline $dest..$branch  | cat
>     echo
> 8e4b2d1 Sys: add PetscDataTypeFromString() and test code
> 22:29:42 2013 -0500
> 248bfaf PCBJacobi: call KSPSetFromOptions(subksp) when PCSetUp was called
> first
> 5b42dca PCGAMG: set bjacobi->same_local_solves=TRUE to clean coarse grid
> viewing
> 2013 +0200
> 17c4b54 Viewer ASCII: print tabs to petsc_history, not fd
> 817ea41 AO: fix erroneous processing of -ao_view and factor into
> AOViewFromOptions
> dba0e79 doc: fix named argument in {Vec,Mat,DM}ViewFromOptions
> 12:23:49 2013 -0500
> 5e9742b Mat PCFactor: include MatFactorShiftType in PCView_Factor output
> 21b6e91 PCMGResidualDefault: fix fortran def [error on windows build]
> 54b2cd4 PCMGResidualDefault: deprecate old semi-private name and make
> public
> 4cf1874 ViennaCL: Added synchronization to bindings just as for CUSP in
> order to allow for correct results with log_summary
> 7121bf1 Added custom FORTRAN stubs for MatCreateAIJViennaCL and
> MatCreateSeqAIJViennaCL
> 023073b Corrected comments in ViennaCL bindings.
> 2f39c30 Improved performance of VecMAXPY_SeqViennaCL and
> VecAXPBYPCZ_SeqViennaCL for gamma=1.
> 65e3cb3 Adjusted parsing of ViennaCL device type options.
> 5e5cd3c Adjusted example config file for ViennaCL
> 50de6e9 Fixed type warning when passing PetscScalar (*)[2] to
> MPI_Allreduce().
> 56f911c Fixed detection of OpenCL on Mac OS.
> 824c3e1 Fixed memory leak in VecGetArray()/VecGetArrayRead() for ViennaCL
> bindings.
> 4f97bae ViennaCL: fix LOCDIR
> ab6435e ViennaCL: Updated code for new interface to
> PetscObjectComposeFunction() and XXXRegister()
> 8ff5867 ViennaCL: Updated to new AMS viewer model
> 586241c ViennaCL: Fixed includedir in viennacl.py package handler
> 0d73d53 ViennaCL: Applied const-correctness to functions.
> 19fddfa ViennaCL: Eliminated whitespace violations, removed/fixed
> erroneous comments.
> b4986ff ViennaCL: Device type can now be specified via command line.
> 4076e18 ViennaCL: Now catching the correct type of exceptions
> (std::exception)
> 0a9f7e6 ViennaCL: Eliminated dead/unused code
> 67c87b7 ViennaCL: Fixed issues if size 0 is passed.
> 3db98f8 ViennaCL: Setting VIENNACL_WITH_OPENCL flag to enable OpenCL
> backend as default.
> dcc04cf ViennaCL: Added package detector for OpenCL, added
> OpenCL-dependency for ViennaCL.
> 8f86e40 ViennaCL: Added MPI-implementation for AIJ matrices.
> 9f10968 ViennaCL: Removed seqviennacl/aijassemble.cxx (would trigger
> error, now uses existing fallback)
> e4a0ef1 ViennaCL: Renamed files to fulfill conventions (.cpp -> .cxx, all
> lowercase), removed restriction of C++ everywhere.
> d67ff14 ViennaCL: Added sequential AIJ matrix.
> 32d0529 ViennaCL: Added MPI vectors.
> ca5856b ViennaCL: Removed unnecessary call to resize() at vector
> construction.
> 3f559ed ViennaCL: Download of package now working.
> b17c682 ViennaCL: First draft, including all operations for sequential
> vectors.
> 506c33d Configure: Fixed logic when using --with-package-lib when the
> package has no includes
> 06:46:26 2013 -0500
> 5a4c130 Mat: fix PetscObjectComm call in last commit
> e22710e Mat: Remove PETSC_COMM_WORLD from MatChop()
> 22:39:10 2013 -0500
> aa932e7 Mat ex170: Comments
> 0e8f585 Mat ex170: Test for MatMult() using max instead of plus - Finds
> the number of connected components in parallel - Can still optimize better
> in parallel
> b434eb9 Mat: Added stuff to let me do (max, mult) algebra things for
> reordering - Added MatMultMax_SeqAIJ() and MatMultAddMax_SeqAIJ() - Added
> PetscSparseDenseMaxDot()
> 849b11c Vec: Added VecUniqueEntries() - This is purely diagnostic, but I
> think its useful for tests
> 745b41b Sys: Added PetscSortRemoveDupsReal()
> 9d2699c PCGAMG Classical: no need to explicitly zero formkktprol
> 65b3d5b Fixed types for PCGAMGProlongator_Classical and
> PCGAMGGraph_Classical, strict C fix.
> 6774142 Complex fixes for classical
> 30454c4 Added test examples for classical AMG
> e5a0faa Fixed a number of bugs in Classical GAMG
> b375234 Fix to the threshold calculation
> f82387e Fixed PCGAMG_Classical so that thresholding decreases fill as bugs
> are fixed
> 3c9ab2c Fixed one-processor memory corruption bug for classical GAMG.
> bfde193 Namespacing in gamg/classical.c
> 8e6d0c3 Added classical AMG to GAMG
> e514fbc Tests for persistent lagging of the Jacobian or Preconditioner
> 9d7e2de Suggested documentation fixes for
> SNESSetLagJacobian/PreconditionerPersists()
> 971e163 SNESSetCountersReset() lets SNES to keep nfuncs and linear_its for
> many solves
> 902f982 Control over initial SNES func/norm in one place; inner ASPIN fix.
> 25a90ac Fixed the behavior of left-pc SNESes preconditioning right-pc
> SNESes.
> 37ec4e1 Added SNESGet/SetLagJacobian/PreconditionerPersists()
> 06:20:21 2013 -0500
> e788a01 dgmres: doc for -ksp_dgmres_view_deflation_vecs
> 9d49465 dgmres: added option to view deflation vecs after solve.
> 62aa035 dgmres: fix real typed as int
> 14:20:33 2013 -0500
> 2591b31 PCFactor: add PCFactorGetLevels
> 0a97e77 PCGAMG: Always rebuild coarse Mat the first time
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130829/7acef163/attachment.html>
