[petsc-dev] git : list branches started off maint - but not yet merged back
Thu Aug 29 20:37:32 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> candidate-branches () {
>>   merged=$1
>>   dest=$2
> what are the arguments here?. Looks a bit complex - so will leave this to you.. :)
Just paste it into your shell, or put it in .bashrc.
$ candidate-branches master maint
Candidate for maint: refs/remotes/origin/balay/fix-deadlock-on-bgq Wed Aug 28 11:57:58 2013 -0500
Candidate for maint: refs/remotes/origin/balay/fix-scalapack-mpiinc Thu Jul 4 14:31:22 2013 -0500
Candidate for maint: refs/remotes/origin/barry/petscdatatypefromstring Fri Aug 23 21:12:13 2013 -0500
Candidate for maint: refs/remotes/origin/jed/fix-gamg-coarse Wed May 29 22:29:42 2013 -0500
Candidate for maint: refs/remotes/origin/jed/fix-viewer-ascii-tab-whitespace Wed Jun 19 09:19:55 2013 +0200
Candidate for maint: refs/remotes/origin/jed/is-view-from-options Sun Aug 25 01:10:01 2013 -0500
Candidate for maint: refs/remotes/origin/jed/mat-factor-shift Sat Jun 1 12:23:49 2013 -0500
Candidate for maint: refs/remotes/origin/jed/pcmg-residual-underscore Wed Jun 26 16:22:39 2013 -0500
Candidate for maint: refs/remotes/origin/karlrupp/feature-viennacl Mon Jun 10 16:44:57 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed Jul 17 07:53:11 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/fix-mat-chop Wed May 29 06:46:26 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/reordering Tue Aug 27 22:39:10 2013 -0500
Candidate for maint: refs/remotes/origin/prbrune/pcgamg-classical Thu Jun 27 12:30:19 2013 -0500
Candidate for maint: refs/remotes/origin/prbrune/snes-npcjacobianlagging Tue May 14 09:50:15 2013 -0500
Candidate for maint: refs/remotes/origin/toby/ksp-dgmres-view Tue Jun 4 06:20:21 2013 -0500
Candidate for maint: refs/remotes/origin/toby/pcfactorgetlevels Fri Jun 7 14:20:33 2013 -0500
Candidate for maint: refs/remotes/origin/toby/pcgamg-rebuild-coarse Wed Jul 24 16:12:18 2013 -0500
> yeah - the thought was - if I could easily find the list of branches -
> then I can look at them - and then ping the relavent folks about it.
Great.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130829/13a6c1a1/attachment.sig>
