[petsc-dev] Why --with-dynamic-loading?
Thu Aug 29 09:07:32 CDT 2013
Lisandro asks why dynamic loading needs a different initialization procedure
#if !defined(PETSC_USE_DYNAMIC_LIBRARIES)
  ierr = KSPInitializePackage();CHKERRQ(ierr);
#endif
Meanwhile, we use normal shared libraries (--with-dynamic-loading=0)
with plugins (petsc4py dynamically loads PETSc and the petsc-eig plugin
is loaded by PETSc and calls back into SLEPc and PETSc).
What is the use case that --with-dynamic-loading is intended to support?
Can we support that use case without having the configuration option?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130829/c23e805b/attachment.sig>
