[petsc-dev] [Bitbucket] Commit 67125ba: metis/parmetis: update to metis-5.1.0/parmetis-4.0.3 (petsc/petsc)
Wed Aug 28 10:24:25 CDT 2013
On Wed, 28 Aug 2013, Karl Rupp wrote:
> Hi Satish,
> >> This is some sort of 'race condition': The latest results from next
> > > become available at about 9am, but it appears that some log files are
> > > moved into the archive-folder already in the evening when the tests on
> > > 'master' are run. Satish can give a better answer on what exactly is
> > > executed when and how.
> > (I think) Satish changed some redirects to make the links stable, but
> > something about it didn't work at that time.  The links work now, but
> > they're still not stable.
> Following Jed's suggestion, can we upload the files directly into the
> respective folder under archive/ ? For example, rather than placing files
> first into
>   http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/
> and then copying them to the archive the next day, can we place them directly
> into
>   http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013-Aug-27/
> and just provide an HTML-forward to that folder in
> ? See the attached Bash-script for generating the necessary file
>   http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html
> for redirection.
Yeah I attempted to copy over to archive folder & generate index.html there [via cron]. But perhaps
my code has bugs.. [and the html forward also is generated each day - because the forward location
changes everyday..]
will check on it..
Satish
