[petsc-dev] [Bitbucket] Commit 67125ba: metis/parmetis: update to metis-5.1.0/parmetis-4.0.3 (petsc/petsc)
Tue Aug 27 13:46:16 CDT 2013
On Tue, 27 Aug 2013, Jed Brown wrote:
> I would remove it,
ok - will do that and update the tarball.
> but shouldn't *we* be picking which options are used to compile?
yes - but I don't know how one does that with cmake [with the current
code listed below]
Perhaps we should strip out this cmake stuff and create some simple
make.inc file as we used to do with earlier permetis versions.. :(
Satish
> Satish Balay <balay at mcs.anl.gov> writes:
> > BTW: meits has this change between 5.0.2 and 5.1.0 - which I can revert
> > [as its the primary cause of this breakage]
> > $ git diff v5.0.2..v5.1.0 GKlib/GKlibSystem.cmake
> > diff --git a/GKlib/GKlibSystem.cmake b/GKlib/GKlibSystem.cmake
> > index 7ea5bab..3fcc291 100644
> > --- a/GKlib/GKlibSystem.cmake
> > +++ b/GKlib/GKlibSystem.cmake
> > @@ -33,7 +33,7 @@ if(CMAKE_COMPILER_IS_GNUCC)
> >        set(GKlib_COPTIONS "${GKlib_COPTIONS} -fPIC")
> >    endif(NOT MINGW)
> >  # GCC warnings.
> > -  set(GKlib_COPTIONS "${GKlib_COPTIONS} -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas")
> > +  set(GKlib_COPTIONS "${GKlib_COPTIONS} -Wall -pedantic -Wno-unused-but-set-variable -Wno-unused-variable -Wno-unknown-pragmas")
> >  elseif(${CMAKE_C_COMPILER_ID} MATCHES "Sun")
> >  # Sun insists on -xc99.
> >    set(GKlib_COPTIONS "${GKlib_COPTIONS} -xc99")
> >> > --- you can reply above this line ---
> >> > New comment on commit:
> >> > https://bitbucket.org/petsc/petsc/commits/67125baed9b71bdad2cf52a801605839abb603c5#comment-394762
> >> > Jed Brown said:
> >> >     Stop in /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt.cc1: error: unrecognized command line option "-Wno-unused-but-set-variable"
> >> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/build_next_arch-freebsd-pkgs-opt_wii.log
> >> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_petsc-mini.mcs.anl.gov.log
> >> cd /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt/libmetis && /usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/mpicc  -Dmetis_EXPORTS -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-but-set-variable -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DHAVE_GETLINE -O3 -fPIC -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/GKlib -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/include -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/libmetis/. -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt/include -o CMakeFiles/metis.dir/__/GKlib/b64.c.o   -c /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/GKlib/b64.c
> >> *** [libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o] Error code 1
> >> *** [libmetis/CMakeFiles/metis.dir/all] Error code 1
> >> *** [all] Error code 1
> >> GKlib/GKlibSystem.cmake has:
> >> # Add compiler flags.
> >> if(MSVC)
> >>   set(GKlib_COPTS "/Ox")
> >>   set(GKlib_COPTIONS "-DWIN32 -DMSC -D_CRT_SECURE_NO_DEPRECATE -DUSE_GKREGEX")
> >> elseif(MINGW)
> >>   set(GKlib_COPTS "-DUSE_GKREGEX")
> >> else()
> >>   set(GKlib_COPTS "-O3")
> >>   set(GKlib_COPTIONS "-DLINUX -D_FILE_OFFSET_BITS=64")
> >> endif(MSVC)
> >> if(CYGWIN)
> >>   set(GKlib_COPTIONS "${GKlib_COPTIONS} -DCYGWIN")
> >> endif(CYGWIN)
> >> # GCC opts.
> >>   set(GKlib_COPTIONS "${GKlib_COPTIONS} -std=c99 -fno-strict-aliasing")
> >>   if(NOT MINGW)
> >>   endif(NOT MINGW)
> >> # GCC warnings.
> >> endif(CMAKE_COMPILER_IS_GNUCC)
> >> Hm - don't unserstand cmake - but looks like metis/parmetis is hardcoding
> >> flags [based on compiler - instead of using user provided flags at configure time?
> >> Executing: cd /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt && /usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=../GKlib -DCMAKE_C_COMPILER="/usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/mpicc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING=" -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O " -DSHARED=1 -DMETIS_USE_DOUBLEPRECISION=1
> >> Is there a way to override this stuff with 'cmake options'? [and not modify this file?]
> >> > (We should probably be making these links stable so that they still make sense tomorrow.)
> >> The stable urls are nightlylogs/archive/date. I'll have the top level
> >> index.html automatically redirect to the correct location - so that
> >> the urls [after redirect] are stable.
> >> Satish
> >> > Unwatch this commit to stop receiving email updates:
> >> > https://bitbucket.org/petsc/petsc/commits/67125baed9b71bdad2cf52a801605839abb603c5/unwatch/balay/225fa74abc610eecc67a3d0e44502277bf0695f1/
