[petsc-dev] [petsc-users] Hypre running out of memory.
Thu Aug 22 10:34:36 CDT 2013
   This issue comes up occasionally. Should we consider having a PETSc option that uses setrlimit() to bound the virtual memory size the process can have? Not a perfect solution but at least something, maybe better than nothing?
   Barry
On Aug 22, 2013, at 8:42 AM, subramanya sadasiva <potaman at outlook.com> wrote:
> Hi,
> I have been trying to use hypre to precondition my Linear Elasticity solver and I've been running out of memory . The problem is that the code is not failing gracefully. The server, where I am running the code on just stops responding and one needs to wait till the code crashes.  Can I force the code to crash gracefully when it runs out of memory?
> Thanks,
> Subramanya
