[petsc-dev] Error while building MAGMA from PETSc
Thu Aug 15 15:29:12 CDT 2013
On Thu, Aug 15, 2013 at 3:24 PM, Harshad Sahasrabudhe
<hsahasra at purdue.edu>wrote:
> It is getting passed... Here is one line from configure.log:
> nvcc -g   -DADD_ -Xcompiler -fno-strict-aliasing -DGPUSHMEM=130
> -DHAVE_CUBLAS -gencode arch=compute_13,code=sm_13 -gencode
> arch=compute_13,code=compute_13 -gencode arch=compute_10,code=compute_10
> -I/home/harshad/cuda-5.5/include -I../include -I../control -c
> zgeadd_batched.cu -o zgeadd_batched.cu_o
During the Magma build. HOWEVER, when you compile with this header, you
need to have this defined as well.
I suggest writing a config header for that package since this "define on
the command
line stuff" is horrible. Then include that header in the regular Magma
header that you are checking for.
   Matt
> From: "Karl Rupp" <rupp at mcs.anl.gov>
> To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>
> Cc: "Barry Smith" <bsmith at mcs.anl.gov>, "For users of the development
> version of PETSc" <petsc-dev at mcs.anl.gov>
> Sent: Thursday, August 15, 2013 4:23:37 PM
> Subject: Re: [petsc-dev] Error while building MAGMA from PETSc
> Hi again,
>  > Yes, -DHAVE_CUBLAS is defined while compilation, but somehow I'm
> getting this error.
> Make sure this also gets passed to the CUDA compiler (nvcc).
> Best regards,
> Karli
> > Sent: Thursday, August 15, 2013 4:18:57 PM
> > Hey,
> > apparently there must be one out of {CUBLAS, clAmdBlas, ICC for MIC}
> > installed. CUBLAS is already made available via --with-cuda, so you
> > should be fine pointing Magma to the CUDA folder. We don't have package
> > checks for clAmdBlas or MIC.
> > Best regards,
> > Karli
> > On 08/15/2013 03:13 PM, Harshad Sahasrabudhe wrote:
> >> How does the testing work? What headers and functions do I need to
> include in magma.py?
> >> From: "Barry Smith" <bsmith at mcs.anl.gov>
> >> Cc: "Jed Brown" <jedbrown at mcs.anl.gov>, "For users of the development
> >> Sent: Thursday, August 15, 2013 4:01:29 PM
> >> Possible ERROR while running preprocessor: In file included from
> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug/include/magmablas_z.h:14:0,
> >>                    from
> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug/include/magmablas.h:12,
> >>                    from
> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug/include/magma.h:15,
> >>                    from /tmp/petsc-Z_wD6e/config.headers/conftest.c:3:
> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug/include/magma_types.h:146:6:
> error: #error "One of HAVE_CUBLAS, HAVE_clAmdBlas, or HAVE_MIC must be
> defined. This typically happens in Makefile.internal."
> >> ret = 256
> >> error message = {In file included from
> >>                    from
> >>                    from
> >> On Aug 15, 2013, at 2:43 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu>
> wrote:
> >>> Attached is the diff and configure.log
> >>> From: "Jed Brown" <jedbrown at mcs.anl.gov>
> >>> To: "Matthew Knepley" <knepley at gmail.com>
> >>> Cc: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>, "For users of the
> development version of PETSc" <petsc-dev at mcs.anl.gov>
> >>> Sent: Thursday, August 15, 2013 3:33:33 PM
> >>> ... and send the changes you have made. One way to do that is to 'git
> add config/PETSc/packages/magma.py' and send the output if 'git diff
> master'.
> >>> On Aug 15, 2013 2:28 PM, "Matthew Knepley" < knepley at gmail.com >
> wrote:
> >>> On Thu, Aug 15, 2013 at 1:56 PM, Harshad Sahasrabudhe <
> hsahasra at purdue.edu > wrote:
> >>> Hi,
> >>> Now MAGMA compiles correctly and libmagma.a is generated, however
> PETSc says
> >>> Downloaded magma could not be used. Please check install in
> >>> I am copying the generated library and include files to the install
> directory using
> >>> includeDir = os.path.join(self.installDir, self.includedir)
> >>> output,err,ret = PETSc.package.NewPackage.executeShellCommand('cd
> '+self.packageDir+' && mv -f lib/*.* '+libDir+'/. && cp -f include/*.*
> '+includeDir+'/.', timeout=2500, log = self.framework.log)
> >>> I need help in resolving this error.
> >>> Always send configure.log.
> >>> Matt
> >>> Thanks,
> >>> Harshad
> >>> From: "Matthew Knepley" < knepley at gmail.com >
> >>> To: "Harshad Sahasrabudhe" < hsahasra at purdue.edu >
> >>> Cc: "For users of the development version of PETSc" <
> petsc-dev at mcs.anl.gov >
> >>> Sent: Wednesday, August 14, 2013 6:27:04 PM
> >>> On Wed, Aug 14, 2013 at 5:23 PM, Harshad Sahasrabudhe <
> >>> Hi,
> >>> I'm trying the write the package compiler for MAGMA using PETSc build
> system. I'm getting the following error while building MAGMA. With the
> error, I'm also getting a couple hundred warnings:
> >>> sormqr_gpu_2stage.cpp: In function ‘magma_int_t
> magma_sormqr_gpu_2stages(char, char, magma_int_t, magma_int_t, magma_int_t,
> float*, magma_int_t, float*, magma_int_t, float*, magma_int_t,
> magma_int_t*)’:
> >>> sormqr_gpu_2stage.cpp:98: warning: unused variable ‘c_one’
> >>> sormqr_gpu_2stage.cpp:107: warning: unused variable ‘lwkopt’
> >>> strsm_m.cpp: In function ‘magma_int_t magma_strsm_m(magma_int_t, char,
> char, char, char, magma_int_t, magma_int_t, float, float*, magma_int_t,
> float*, magma_int_t)’:
> >>> strsm_m.cpp:181: warning: unused variable ‘jj’
> >>> strsm_m.cpp:181: warning: unused variable ‘jjb’
> >>> sgeev.cpp: In function ‘magma_int_t magma_sgeev(char, char,
> magma_int_t, float*, magma_int_t, float*, float*, float*, magma_int_t,
> float*, magma_int_t, float*, magma_int_t, magma_int_t*)’:
> >>> sgeev.cpp:126: warning: unused variable ‘c_n1’
> >>> nvcc fatal : redefinition of argument 'gpu-architecture'
> >>> What is the easiest way to debug this kind of an error?
> >>> 1) Make the MAGMA build system print out the full compile line
> >>> 2) Make the MAGMA people clean up their sloppy code, which would
> eliminate the warnings
> >>> Matt
> >>> Thanks,
> >>> Harshad
> >>> What most experimenters take for granted before they begin their
> experiments lead.
> >>> -- Norbert Wiener
> experiments lead.
> >>> -- Norbert Wiener<diff_magma><configure.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130815/ee4158a0/attachment.html>
