[petsc-dev] Error while building MAGMA from PETSc
Harshad Sahasrabudhe hsahasra at purdue.edu
Wed Aug 14 17:23:34 CDT 2013
I'm trying the write the package compiler for MAGMA using PETSc build system. I'm getting the following error while building MAGMA. With the error, I'm also getting a couple hundred warnings:
sormqr_gpu_2stage.cpp: In function ‘magma_int_t magma_sormqr_gpu_2stages(char, char, magma_int_t, magma_int_t, magma_int_t, float*, magma_int_t, float*, magma_int_t, float*, magma_int_t, magma_int_t*)’:
sormqr_gpu_2stage.cpp:98: warning: unused variable ‘c_one’
sormqr_gpu_2stage.cpp:107: warning: unused variable ‘lwkopt’
strsm_m.cpp: In function ‘magma_int_t magma_strsm_m(magma_int_t, char, char, char, char, magma_int_t, magma_int_t, float, float*, magma_int_t, float*, magma_int_t)’:
strsm_m.cpp:181: warning: unused variable ‘jj’
strsm_m.cpp:181: warning: unused variable ‘jjb’
sgeev.cpp: In function ‘magma_int_t magma_sgeev(char, char, magma_int_t, float*, magma_int_t, float*, float*, float*, magma_int_t, float*, magma_int_t, float*, magma_int_t, magma_int_t*)’:
sgeev.cpp:126: warning: unused variable ‘c_n1’
nvcc fatal : redefinition of argument 'gpu-architecture'
What is the easiest way to debug this kind of an error?
Harshad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130814/0989dc25/attachment.html>
