[petsc-dev] Hybrid MPI/OpenMP reflections
Fri Aug 9 16:42:43 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Generally there should be some non zeros in each row, we could
>    probably just use 2.0*a->nz - m
When using cprow, this should always be exact, right?
If we are not using cprow because there weren't enough empty rows, but
there are still some empty rows, it won't be exact, but it's likely not
far off for typical matrices.  It would be a shame, however, that we
could now compute a negative number of flops.  Should the check for
cprow store the number of zero rows?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130809/d95b0c6e/attachment.sig>
