[petsc-dev] generating html pages
Fri Aug 9 11:15:42 CDT 2013
Note: doc generation has sequential dependencies - so to do 'make
manualpages LOC=$PETSC_DIR' in any given source tree - make sure the
previous seteps are done atleast once.
i.e
cd PETSC_DIR
make alldoc1 LOC=$PETSC_DIR
cd src/ksp/ksp/interface
make manualpages LOC=$PETSC_DIR
Satish
alldoc: alldoc1 alldoc2 alldoc3 docsetdate
# Build everything that goes into 'doc' dir except html sources
alldoc1: chk_loc deletemanualpages chk_concepts_dir
        -${PYTHON} bin/maint/countpetsccits.py
        -${OMAKE} ACTION=manualpages_buildcite tree_basic LOC=${LOC}
        - at sed -e s%man+../%man+manualpages/% ${LOC}/docs/manualpages/manualpages.cit > ${LOC}/docs/manualpages/htmlmap
        - at cat ${PETSC_DIR}/src/docs/mpi.www.index >> ${LOC}/docs/manualpages/htmlmap
        -cd src/docs/tex/manual; ${OMAKE} manual.pdf LOC=${LOC}
        -cd src/docs/tex/manual; ${OMAKE} developers.pdf LOC=${LOC}
        -${OMAKE} ACTION=manualpages tree_basic LOC=${LOC}
        -${PYTHON} bin/maint/wwwindex.py ${PETSC_DIR} ${LOC}
        -${OMAKE} ACTION=manexamples tree_basic LOC=${LOC}
        -${OMAKE} manconcepts LOC=${LOC}
        -${OMAKE} ACTION=getexlist tree_basic LOC=${LOC}
        -${OMAKE} ACTION=exampleconcepts tree_basic LOC=${LOC}
        -${PYTHON} bin/maint/helpindex.py ${PETSC_DIR} ${LOC}
# Builds .html versions of the source
# html overwrites some stuff created by update-docs - hence this is done later.
alldoc2: chk_loc
        -${OMAKE} ACTION=html PETSC_DIR=${PETSC_DIR} alltree LOC=${LOC}
        -${PYTHON} bin/maint/update-docs.py ${PETSC_DIR} ${LOC}
# Builds HTML versions of Matlab scripts
alldoc3: chk_loc
        if  [ "${MATLAB_COMMAND}" != "" ]; then\
          export MATLABPATH=${MATLABPATH}:${PETSC_DIR}/bin/matlab; \
          cd ${PETSC_DIR}/bin/matlab; ${MATLAB_COMMAND} -nodisplay -nodesktop -r "generatehtml;exit" ; \
          cd classes; ${MATLAB_COMMAND} -nodisplay -nodesktop -r "generatehtml;exit" ; \
          cd examples/tutorials; ${MATLAB_COMMAND} -nodisplay -nodesktop -r "generatehtml;exit" ; \
        fi
On Fri, 9 Aug 2013, Barry Smith wrote:
>    In the directory in question run make manualpages  with LOC set appropriately.
>    Barry
> On Aug 9, 2013, at 10:17 AM, Stefano Zampini <s.zampini at cineca.it> wrote:
> > I'm currently creating manual pages for PCBDDC.
> > To obtain the html, I currently run make alldoc, which takes 40 minutes on my laptop, rebuilding everything from scratch.
> > Is there a faster way to produce manual pages for a single directory?
> > Ph. D. Stefano Zampini
> > CINECA
> > SuperComputing Applications and Innovations Department - SCAI
> > Via dei Tizii, 6 00185 Roma - ITALY
> > Email:
> > SkypeID: stefano.zampini
> > GoogleTalk:
> > stefano.zampini at gmail.com
> > Tel:
> > +39 06.44486.707
