[petsc-dev] Removal of PETSC_VIEWER_NATIVE?
Fri Aug 9 09:32:06 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> I don't disagree, but should we go all the way to a closed model to
> fix this, or should we just pick out cases like this and catch them?
Perhaps different formats should be different viewer types.  It is just
an implementation detail that VTK ASCII uses ASCII characters.  You
can't share any writing code between the two.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130809/00237136/attachment.sig>
