[petsc-dev] Valgrind invalid read in GAMG
John Mousel john.mousel at gmail.com
Fri Aug 9 08:49:51 CDT 2013
I'm getting the following invalid read when I use GAMG. I've included the
output of KSPView at the bottom.
==18312== Memcheck, a memory error detector
==18312== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward et al.
==18312== Using Valgrind-3.8.1 and LibVEX; rerun with -h for copyright info
==18312== Command: ../src/CYLINDER_EXE -ELAFINT_case_name cylinder
-lspaint_ksp_type bcgsl -lspaint_pc_type gamg -lspaint_pc_gamg_type agg
-lspaint_pc_gamg_agg_nsmooths 1 -lspaint_pc_gamg_sym_graph true
-lspaint_ksp_monitor -pres_ksp_type preonly -pres_pc_type redistribute
-pres_redistribute_ksp_type bcgsl -pres_redistribute_pc_type gamg
-pres_redistribute_pc_gamg_threshold 0.05
-pres_redistribute_mg_levels_ksp_type richardson
-pres_redistribute_mg_levels_pc_type sor
-pres_redistribute_mg_coarse_ksp_type richardson
-pres_redistribute_mg_coarse_pc_type sor
-pres_redistribute_mg_coarse_pc_sor_its 5 -pres_redistribute_pc_gamg_type
agg -pres_redistribute_pc_gamg_agg_nsmooths 2
-pres_redistribute_pc_gamg_sym_graph true
-pres_redistribute_ksp_initial_guess_nonzero 0 -vel_ksp_monitor
-pres_redistribute_ksp_monitor
==18312== Parent PID: 18308
==18312==
==18311== Invalid read of size 8
==18311==    at 0x4DF2BDC: PetscCheckPointer (checkptr.c:52)
==18311==    by 0x54370DE: MatSetValues_MPIAIJ (mpiaij.c:506)
==18311==    by 0x5462AA8: MatGetSubMatrix_MPIAIJ_Private (mpiaij.c:3860)
==18311==    by 0x5461799: MatGetSubMatrix_MPIAIJ (mpiaij.c:3733)
==18311==    by 0x551B5E8: MatGetSubMatrix (matrix.c:7322)
==18311==    by 0x5817535: createLevel (gamg.c:404)
==18311==    by 0x5819420: PCSetUp_GAMG (gamg.c:630)
==18311==    by 0x5764D93: PCSetUp (precon.c:890)
==18311==    by 0x589B211: KSPSetUp (itfunc.c:278)
==18311==    by 0x589C39A: KSPSolve (itfunc.c:399)
==18311==    by 0x57555E1: kspsolve_ (itfuncf.c:219)
==18311==    by 0x61B7A6: axbsolve_ (Axb.F90:139)
==18311==  Address 0x83d9c20 is 9,376 bytes inside a block of size 9,380
alloc'd
==18311==    at 0x4A06548: memalign (vg_replace_malloc.c:727)
==18311==    by 0x4DF2C7D: PetscMallocAlign (mal.c:==18309==
==18309== HEAP SUMMARY:
==18309==     in use at exit: 3,262,243 bytes in 17,854 blocks
==18309==   total heap usage: 329,856 allocs, 312,002 frees, 136,790,072
bytes allocated
==18309==
==18309== LEAK SUMMARY:
==18309==    definitely lost: 0 bytes in 0 blocks
==18309==    indirectly lost: 0 bytes in 0 blocks
==18309==      possibly lost: 0 bytes in 0 blocks
==18309==    still reachable: 3,262,243 bytes in 17,854 blocks
==18309==         suppressed: 0 bytes in 0 blocks
==18309== Rerun with --leak-check=full to see details of leaked memory
==18309==
==18309== For counts of detected and suppressed errors, rerun with: -v
==18309== Use --track-origins=yes to see where uninitialised values come
from
==18309== ERROR SUMMARY: 24 errors from 1 contexts (suppressed: 6 from 6)
,141 frees, 130,288,754 bytes allocated
==18310======18310== LEAK SUMMARY:
==18310==    definitely lost: 0 bytes in 0 blocks
==18310==    indirectly lost: 0 bytes in 0 blocks
==18310==      possibly lost: 0 bytes in 0 blocks
==18310==    still reachable: 3,376,159 bytes in 18,772 blocks
==18310==         suppressed: 0 bytes in 0 blocks
==18310== Rerun with --leak-check=full to see details of leaked memory
==18310==
==18310== For counts of detected and suppressed errors, rerun with: -v
==18310== ERROR SUMMARY: 2 errors from 1 contexts (suppressed: 6 from 6)
KSP Object:(pres_) 4 MPI processes
  type: preonly
  maximum iterations=20000, initial guess is zero
  tolerances:  relative=5e-08, absolute=1e-50, divergence=10000
  left preconditioning
  using NONE norm type for convergence test
PC Object:(pres_) 4 MPI processes
  type: redistribute
      Number rows eliminated 820 Percentage rows eliminated 11.6213
    Redistribute preconditioner:
  KSP Object:  (pres_redistribute_)   4 MPI processes
    type: bcgsl
      BCGSL: Ell = 2
      BCGSL: Delta = 0
    has attached null space
    using PRECONDITIONED norm type for convergence test
  PC Object:  (pres_redistribute_)   4 MPI processes
    type: gamg
      MG: type is MULTIPLICATIVE, levels=3 cycles=v
        Cycles per PCApply=1
        Using Galerkin computed coarse grid matrices
    Coarse grid solver -- level -------------------------------
      KSP Object:      (pres_redistribute_mg_coarse_)       4 MPI processes
        type: preonly
        maximum iterations=1, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      PC Object:      (pres_redistribute_mg_coarse_)       4 MPI processes
        type: sor
          SOR: type = local_symmetric, iterations = 5, local iterations =
1, omega = 1
        linear system matrix = precond matrix:
        Mat Object:         4 MPI processes
          type: mpiaij
          rows=61, cols=61
          total: nonzeros=1846, allocated nonzeros=1846
          total number of mallocs used during MatSetValues calls =0
            not using I-node (on process 0) routines
    Down solver (pre-smoother) on level 1 -------------------------------
      KSP Object:      (pres_redistribute_mg_levels_1_)       4 MPI
processes
        type: richardson
          Richardson: damping factor=1
        using nonzero initial guess
      PC Object:      (pres_redistribute_mg_levels_1_)       4 MPI processes
        type: sor
          SOR: type = local_symmetric, iterations = 1, local iterations =
1, omega = 1
          type: mpiaij
          rows=870, cols=870
          total: nonzeros=16020, allocated nonzeros=16020
    Up solver (post-smoother) same as down solver (pre-smoother)
    Down solver (pre-smoother) on level 2 -------------------------------
      KSP Object:      (pres_redistribute_mg_levels_2_)       4 MPI
processes
        type: richardson
      PC Object:      (pres_redistribute_mg_levels_2_)       4 MPI processes
        type: sor
1, omega = 1
          type: mpiaij
          rows=6236, cols=6236
          total: nonzeros=31220, allocated nonzeros=31220
      type: mpiaij
    type: mpiaij
    rows=7056, cols=7056
    total: nonzeros=32416, allocated nonzeros=33180
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130809/905075fd/attachment.html>
