[petsc-dev] RDict import fragility
Mon Aug 5 12:13:13 CDT 2013
On Mon, Aug 5, 2013 at 12:10 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > I guess we could prune modules that are not found before saving.
> This won't help because the module was found when saving, just not when
> loading.  But what about pruning modules that are not _used_ when saving?
You misunderstand. I mean modules with self.found = 0, so the same as you
mean above.
> > I was under the impression that reconfiguring after source changes to
> > BuildSystem was not a big deal.
> These are source changes to parts of BuildSystem and PETSc that I'm not
> using at all.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130805/811b8f54/attachment.html>
