[petsc-dev] deleting my old forks on bitbucket.
Karl Rupp rupp at mcs.anl.gov
Thu Aug 1 11:15:52 CDT 2013
oh, right, if you actually want to delete the whole repository, you
should do it from Bitbucket directly. I thought you wanted just to
delete the branch.
Best regards,
Karli
On 08/01/2013 11:11 AM, Satish Balay wrote:
> You might have to login to your bitbucket account - and delete the repo.
> Satish
> On Thu, 1 Aug 2013, Paul Mullowney wrote:
>> Hi Karli,
>> So I want to eliminate pmullowney/petsc-aijcusparse-icc.git. Would I do:
>> git push https://bitbucket.org/petsc/petsc.git
>> :pmullowney/petsc-aijcusparse-icc.git
>> Do I do this in a locally cloned version of next or of
>> pmullowney/petsc-aijcusparse-icc.git?
>> Also, do you see any reason to keep pmullowney/txpetscgpu-package-removal.git
>> around? I don't.
>> Thanks for your help.
>> -Paul
>>> Hi Paul,
>>> git push origin :branchname
>>> should work.
>>> Best regards,
>>> Karli
>>> On 08/01/2013 10:40 AM, Paul Mullowney wrote:
>>>> How do I do this?
>>>> -Paul
