[petsc-dev] The problem about running an example in PETSc
Lulu Liu lulu.liu at kaust.edu.sa
Tue Apr 30 13:09:05 CDT 2013
src/ts/examples/tutorials/ex29.c I want domain partition is 1x2
mpiexec -n 2 ./ex29 -da_refine 4 -ts_max_steps 10 -ts_rtol 1e-3 -ts_atol
1e-3   -ts_type arkimex -ts_monitor -snes_monitor -snes_type ngmres
-npc_snes_type nasm -npc_snes_nasm_type restrict -da_overlap 4
 -da_processors_x 1 -da_processors_y 2
0 TS dt 0.05 time 0
    0 SNES Function norm 1.762942085583e+01
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: Too many processors in Y direction: 2 1!
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range!
[1]PETSC ERROR: Too many processors in Y direction: 2 1!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Development GIT revision:
bc51b945dfb4f1d1228fb677a132a806066a0f32  GIT Date: 2013-04-29 10:22:29
-0500
[0]PETSC ERROR: Petsc Development GIT revision:
-0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex29 on a arch-basic named kl-12681.local by liul Tue Apr
30 21:07:37 2013
[0]PETSC ERROR: [1]PETSC ERROR: See docs/changes/index.html for recent
updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: ./ex29 on a arch-basic named kl-12681.local by liul Tue Apr
30 21:07:37 2013
[1]PETSC ERROR: Libraries linked from /Users/liul/soft/petsc/arch-basic/lib
[1]PETSC ERROR: Configure run at Tue Apr 30 15:46:16 2013
[1]PETSC ERROR: Configure options --download-cmake --download-f-blas-lapack
--download-mpich --with-cc=gcc --with-fc=gfortran PETSC_ARCH=arch-basic
[1]PETSC ERROR:
[0]PETSC ERROR: Configure run at Tue Apr 30 15:46:16 2013
[0]PETSC ERROR: Configure options --download-cmake --download-f-blas-lapack
[0]PETSC ERROR:
[0]PETSC ERROR: DMSetUp_DA_2D() line 266 in
/Users/liul/soft/petsc/src/dm/impls/da/da2.c
DMSetUp_DA_2D() line 266 in /Users/liul/soft/petsc/src/dm/impls/da/da2.c
[1]PETSC ERROR: DMSetUp_DA() line 27 in
/Users/liul/soft/petsc/src/dm/impls/da/dareg.c
[1]PETSC ERROR: DMSetUp() line 469 in
/Users/liul/soft/petsc/src/dm/interface/dm.c
[1]PETSC ERROR: DMDACreate2d() line 888 in
[1]PETSC ERROR: [0]PETSC ERROR: DMSetUp_DA() line 27 in
[0]PETSC ERROR: DMSetUp() line 469 in
DMDAGetReducedDMDA() line 389 in
/Users/liul/soft/petsc/src/dm/impls/da/dacorn.c
[1]PETSC ERROR: CoefficientSubDomainRestrictHook() line 92 in
[1]PETSC ERROR: DMCreateDomainDecomposition() line 1314 in
[1]PETSC ERROR: SNESSetUp_NASM() line 112 in
/Users/liul/soft/petsc/src/snes/impls/nasm/nasm.c
[1]PETSC ERROR: SNESSetUp() line 2633 in
/Users/liul/soft/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: DMDACreate2d() line 888 in
[0]PETSC ERROR: DMDAGetReducedDMDA() line 389 in
[0]PETSC ERROR: CoefficientSubDomainRestrictHook() line 92 in
[0]PETSC ERROR: [1]PETSC ERROR: SNESSolve() line 3743 in
[1]PETSC ERROR: SNESSolve_NGMRES() line 249 in
/Users/liul/soft/petsc/src/snes/impls/ngmres/snesngmres.c
[1]PETSC ERROR: SNESSolve() line 3755 in
[1]PETSC ERROR: TSStep_ARKIMEX() line 765 in
/Users/liul/soft/petsc/src/ts/impls/arkimex/arkimex.c
[1]PETSC ERROR: TSStep() line 2457 in
/Users/liul/soft/petsc/src/ts/interface/ts.c
[1]PETSC ERROR: TSSolve() line 2584 in
[1]PETSC ERROR: main() line 163 in src/ts/examples/tutorials/ex29.c
[0]PETSC ERROR: SNESSetUp_NASM() line 112 in
[0]PETSC ERROR: SNESSetUp() line 2633 in
[0]PETSC ERROR: SNESSolve() line 3743 in
[0]PETSC ERROR: SNESSolve_NGMRES() line 249 in
[0]PETSC ERROR: SNESSolve() line 3755 in
[0]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 63) - process 1
[cli_1]: aborting job:
[0]PETSC ERROR: TSStep() line 2457 in
[0]PETSC ERROR: TSSolve() line 2584 in
[0]PETSC ERROR: main() line 163 in src/ts/examples/tutorials/ex29.c
application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
[cli_0]: aborting job:
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130430/034b7e5c/attachment.html>
