[petsc-dev] usage of string.h
Thu Apr 25 17:56:07 CDT 2013
pushed fix to next.
https://bitbucket.org/petsc/petsc/commits/6ce87071a70dc571b20c8dec584cf34b3dea0b34
satish
On Thu, 25 Apr 2013, Satish Balay wrote:
> I see the usage of string.h is removed from petsc sources.
> https://bitbucket.org/petsc/petsc/commits/b083e2b6e0be6f731fe9e787c55cf4647c46b29
> https://bitbucket.org/petsc/petsc/commits/573b0fb4b27458e353e9b121e629dc5c63cf6459
> The remove of strings.h from str.c is added back in
> https://bitbucket.org/petsc/petsc/commits/3964eb8815a373d98cd54ebd45324cfa27b228df
> Now I see a breakage in windows64 build with strstr() [usded in str.c]
> - fixable by adding back string.h
> Is this the correct fix? Whats the intention of remove these includes?
> thanks,
> Satish
