[petsc-dev] Fwd: [petsc-users] PCView only for one block ?
Tue Apr 16 21:51:06 CDT 2013
On Apr 16, 2013, at 8:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>   Someone has been mucking with PCView_BJacobi? Under normal
> Mikolaj, can you show the code that you use for setting up this bjacobi?
> FWIW, src/snes/examples/tutorials/ex7.c also produces verbose output.  I
> understand the desire to show details when someone configures each
> subdomain differently, but I'd still rather have scalable output by
> default.
    It doesn't for me. In fact in next it doesn't even run in parallel, is this expected behavior?
~/Src/petsc/src/snes/examples/tutorials  next $ petscmpiexec -n 2 ./ex7 -snes_view
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start of the function
[1]PETSC ERROR:       is given.
[1]PETSC ERROR: [1] FormFunctionLocal line 377 src/snes/examples/tutorials/ex7.c
[1]PETSC ERROR: [1] SNESComputeFunction_DMDA line 79 /Users/barrysmith/Src/PETSc/src/snes/utils/dmdasnes.c
[1]PETSC ERROR: [1] SNES user function line 0 unknownunknown
[1]PETSC ERROR: [1] SNESComputeFunction line 2016 /Users/barrysmith/Src/PETSc/src/snes/interface/snes.c
[1]PETSC ERROR: [1] SNESSolve_NEWTONLS line 145 /Users/barrysmith/Src/PETSc/src/snes/impls/ls/ls.c
[1]PETSC ERROR: [1] SNESSolve line 3708 /Users/barrysmith/Src/PETSc/src/snes/interface/snes.c
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR: Petsc Development GIT revision: acc80a61d235fd808c6194a016f8a1e2727e30e4  GIT Date: 2013-04-07 17:28:52 -0500
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./ex7 on a arch-g++ named Barrys-MacBook-Pro.local by barrysmith Tue Apr 16 21:05:19 2013
[1]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/PETSc/arch-g++/lib
[1]PETSC ERROR: Configure run at Sun Apr  7 17:35:21 2013
[1]PETSC ERROR: Configure options --download-mpich --with-clanguage=c++ --with-dynamic-loading --with-shared-libraries --with-single-library=0 PETSC_ARCH=arch-g++ --with-fc=0
[1]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
[cli_1]: aborting job:
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 59
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
