[petsc-dev] manual pages
Sat Apr 13 12:39:05 CDT 2013
set LOC to PETSC_DIR
Also - due to the depencencies withn the doc generation - you might
have to do the 'alldoc1' stuff - atleast to the manualpage generation
step [atleast once]
alldoc1: chk_loc deletemanualpages chk_concepts_dir
        -${PYTHON} bin/maint/countpetsccits.py
        -${OMAKE} ACTION=manualpages_buildcite tree_basic LOC=${LOC}
        - at sed -e s%man+../%man+manualpages/% ${LOC}/docs/manualpages/manualpages.cit > ${LOC}/docs/manualpages/htmlmap
        - at cat ${PETSC_DIR}/src/docs/mpi.www.index >> ${LOC}/docs/manualpages/htmlmap
        -cd src/docs/tex/manual; ${OMAKE} manual.pdf LOC=${LOC}
        -cd src/docs/tex/manual; ${OMAKE} developers.pdf LOC=${LOC}
Satish
On Sat, 13 Apr 2013, Mark F. Adams wrote:
> I'm trying to add a GAMG section to the manual and am having problems building it:
> 13:15 2 madams/manual-gamg ~/Codes/petsc/src/docs/tex/manual$ make manual.pdf LOC=/var/tmp
> Traceback (most recent call last):
>   File "../../../../bin/maint/mapnameslatex.py", line 204, in <module>
>     raise RuntimeError('Unable to open htmlmap-file: '+htmlmapfile+'\n')
> RuntimeError: Unable to open htmlmap-file: /var/tmp/docs/manualpages/htmlmap
> make: [manual.pdf] Error 1 (ignored)
> /opt/local/bin/pdflatex -halt-on-error manual1  > /dev/null 2>&1
> bibtex manual1 > /dev/null 2>&1
> make: [manual.pdf] Error 2 (ignored)
> makeindex manual1  > /dev/null 2>&1
> /bin/mv part2tmp.tex tmp
> grep -v "end{theindex}" tmp > part2tmp.tex
> make: *** [manual.pdf] Error 1
> Clearly I'm not using LOC correctly ….
