[petsc-dev] macro wrappers around functions to caste suck
Sun Apr 7 16:46:53 CDT 2013
On Apr 7, 2013, at 4:16 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>   That was my rationalization for ugly code; until a better solution
>>   appeared and I no longer needed the rationalization :-)
> Okay, are we removing _all_ those casts, or only for a few highly-used
> PetscObject functions?  PetscObjectComm() is one we changed recently.
  Seems inconsistent to only handle the cast automatically for some. We should do it all or nothing. That is be C++ish and let the user always pass a subclass where the class is expected or be C ish and always require the cast.
> Note that absorbing the cast into the macro is backward-compatible in
> that code with an explicit cast continues to work without a warning.
   Ok, then we shouldn't make this change, you know I hate changes that are backward compatible :-)
