[petsc-dev] XXXRegisterDestroy() are not called
Fri Apr 5 20:28:11 CDT 2013
[Cc'ing Lisandro because petsc4py seems to be most sensitive to changes
like this, though I don't think this affects him.]
On Fri, Apr 5, 2013 at 8:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Currently PetscFunctionListAdd() maintains a list of all function lists in
> existence and in PetscFinalize() PetscFunctionListDestroyAll() loops over
> all the list of lists destroying each list. Thus all of these lists are
> destroyed without the XXXRegisterDestroy() needing to be called. A drawback
> is that PetscFunctionListDestroyAll() is called before some of the
> XXXFinalizePackage() are called thus leaving XXXList global variables
> pointing to freed memory (this is why for example VecFinalizePackage() has
>   VecList               = NULL; in it.)
>   I propose the following change; each appropriate XXXFinalizePackage()
> call the appropriate XXXRegisterDestroy() (this would replace the VecList
>             = NULL; lines) and PetscFunctionListDestroyAll() be renamed to
> just generate a dump of any lists that don't get properly freed.
Okay, note that PetscFunctionListAdd could store the address of the
FunctionList (which it is passed) rather than just the list, in which case
PetscFunctionListDestroyAll() would be able to zero VecList itself, getting
rid of the problem of dangling lists.
I think we should either do what you propose and consistently make
VecList/MatList/etc static or we should consistently make them visible, get
rid of VecRegisterAllCalled (which is redundant if
PetscFunctionListDestroyAll can zero VecList by storing the pointer), and
do away with all the XRegisterDestroy functions.
I may be wrong, but I think it's rare that a user really wants to
selectively clear a FunctionList, and in the rare case that they need it,
PetscFunctionListDestroy(&VecList) would do the trick.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130405/6321b7c2/attachment.html>
