[petsc-dev] Fwd: [petsc-users] C compiler you provided with -with-cc=win32fe cl does not work
Sun Sep 23 14:16:10 CDT 2012
> Try after extracting petsc in a directory which does not contain a space in its name.
    Satish,
     Can we have ./configure check this issue as soon as it starts up and generate a useful error message?
    Thanks
     Barry
> Chetan
> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Yifei Li
> Sent: Sunday, September 23, 2012 11:03 AM
> To: PETSc users list
> Subject: [petsc-users] C compiler you provided with -with-cc=win32fe cl does not work
> Hi,
> I tried to build petsc on a  maching running 32-bit Windows XP with SP3.
> I got the above error after running configure
> Attached is the log file. Any help is appreciated.
> Yifei
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120923/e4b4e655/attachment.html>
