[petsc-dev] Enabling single precision for MUMPS and SUPERLU
Stefano Zampini stefano.zampini at gmail.com
Sat Sep 22 04:56:21 CDT 2012
Sorry Hong, I forgot to pull before doing the patches. Please find attached
the patches made with the latest dev
(changeset 24444 92061a43c7a4)
Stefano
2012/9/21 Hong Zhang <hzhang at mcs.anl.gov>
> Stefano:
> Are you sure these patches are made out of the latest petsc-dev?
> I get
> petsc:/sandbox/hzhang/petsc-dev>patch -Np1 < superlu_patch_single.diff
> patching file config/PETSc/packages/SuperLU.py
> patching file src/mat/impls/aij/seq/superlu/makefile
> patching file src/mat/impls/aij/seq/superlu/superlu.c
> Hunk #1 FAILED at 21.
> Hunk #2 FAILED at 142.
> Hunk #4 FAILED at 311.
> Hunk #5 succeeded at 517 with fuzz 2.
> Hunk #6 FAILED at 569.
> Hunk #8 succeeded at 618 with fuzz 1.
> 4 out of 8 hunks FAILED -- saving rejects to file
> src/mat/impls/aij/seq/superlu/superlu.c.rej
> Similar error on mumps_patch_single.diff.
> Patching petsc-3.3 is successful though.
> Barry: do you agree with Stefano's approach?
> Hong
> Hong, attached please find the two patches split.
>>> Stefano:
>>>> When Hong has finished testing, I will split the patches and commit
>>>> them. Please let me know what macro name you'll choose (or the ugly choice
>>>> of course)
>>> How about split the patches now?
>>> Then I'll test one package at a time.
>>> Hong
>>>> There is also pastix which can be enabled, but the problem is that it
>>>> requires pt-scotch for partitioning, and in turn pt-scotch will become a
>>>> possible method to be used in MatPartitioning class. Maybe someone can
>>>> think about adding a new command line argument in package configure which
>>>> guaranties you will use a library (pt-scotch) only inside  pastix and not
>>>> within the MatPartitioning class? (maybe using self.useddirectly in
>>>> config/BuildSystem/package.py)
>>>> Stefano
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120922/f2bc6739/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120922/f2bc6739/attachment.gz>
