[petsc-dev] Bad fortran interface generations
Tue Sep 18 13:42:39 CDT 2012
   /usr/local/bin/bfort must be the old one that continued lines that exactly fit and thus confused the bg compiler.
   the --download brings down the latest sowing with the fix for continued lines.
    Barry
Someone should remove the  /usr/local/bin. one.
On Sep 18, 2012, at 1:37 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> externalpackages/sowing* is empty in my broken source. Bgq has bfort in /usr/local/bin. actual petsc-dev version recognized it and thus use it.
> I switched to require --download-sowing in configure and this solves the problem. There was any change in config related to don't use sowing by default recently?
> Thanks,
> Stefano
> 2012/9/18 Satish Balay <balay at mcs.anl.gov>
> Can you do rm -rf externalpackages/sowing* and rerun configure - and
> see if the problem persists?
> Satish
> On Tue, 18 Sep 2012, Stefano Zampini wrote:
> > Something is changed between HG revision
> > ce7508606e824d026ea20d05da900e98f37b3864 and the current tip which affected
> > the automatic generation of Fortran Interfaces.
> > In particular, PETSc-dev compilation is now broken on some .h90 headers
> > created in include/finclude/ftn-auto/.
> > For example, in include/finclude/ftn-auto/petscvec.h90 for the current tip
> >         subroutine VecGhostUpdateBegin(g, insertmode, scattermode ,ierr)&
> > whereas for ce7508606e824d026ea20d05da900e98f37b3864
> > The form with ampersand is a sintax error for bgxlf90. Removing the two
> > ampersands solves the problem.
> > "/fermi/home/userprod/propro01/szampini/petsc-dev/include/finclude/petscvec.h90",
> > line 9.7: 1515-019 (S) Syntax is incorrect.
> > "/fermi/home/userprod/propro01/szampini/petsc-dev/src/vec/f90-mod/petscvecmod.F",
> > line 25.8: 1513-085 (S) Improper END statement specified. This END
> > statement will be matched with the program unit or procedure named _main.
> > ** _main   === End of Compilation 138 ===
> Stefano
