[petsc-dev] Bad fortran interface generations
Stefano Zampini stefano.zampini at gmail.com
Tue Sep 18 08:49:04 CDT 2012
Something is changed between HG revision
ce7508606e824d026ea20d05da900e98f37b3864 and the current tip which affected
the automatic generation of Fortran Interfaces.
In particular, PETSc-dev compilation is now broken on some .h90 headers
created in include/finclude/ftn-auto/.
For example, in include/finclude/ftn-auto/petscvec.h90 for the current tip
        subroutine VecGhostUpdateBegin(g, insertmode, scattermode ,ierr)&
whereas for ce7508606e824d026ea20d05da900e98f37b3864
The form with ampersand is a sintax error for bgxlf90. Removing the two
ampersands solves the problem.
"/fermi/home/userprod/propro01/szampini/petsc-dev/include/finclude/petscvec.h90",
line 9.7: 1515-019 (S) Syntax is incorrect.
"/fermi/home/userprod/propro01/szampini/petsc-dev/src/vec/f90-mod/petscvecmod.F",
line 25.8: 1513-085 (S) Improper END statement specified. This END
statement will be matched with the program unit or procedure named _main.
** _main   === End of Compilation 138 ===
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120918/c8ff5bf8/attachment.html>
