[petsc-dev] WHo the Fuck Broke the Repository
Mon Sep 17 20:14:02 CDT 2012
remote: adding changesets
remote: adding manifests
remote: adding file changes
remote: added 2 changesets with 5 changes to 5 files
remote: pushing to ssh://hg@bitbucket.org/petsc/petsc-dev
remote: searching for changes
remote: remote: adding changesets
remote: remote: adding manifests
remote: remote: adding file changes
remote: remote: added 2 changesets with 5 changes to 5 files
remote: remote: transaction abort!
remote: remote: rollback completed
remote: remote: ** unknown exception encountered, please report by visiting
remote: remote: ** http://mercurial.selenic.com/wiki/BugTracker
remote: remote: ** Python 2.7.3 (default, Apr 23 2012, 00:40:27) [GCC 4.4.6
20110731 (Red Hat 4.4.6-3)]
remote: remote: ** Mercurial Distributed SCM (version 2.2.2+11-cab7fc8c33b6)
remote: remote: ** Extensions loaded: convert
remote: remote: Traceback (most recent call last):
remote: remote:   File "/opt/python/domains/
bitbucket.org/2012-08-14/bitbucket/local/env/bin/hg", line 38, in <module>
remote: remote:     mercurial.dispatch.run()
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/dispatch.py",
line 28, in run
remote: remote:     sys.exit((dispatch(request(sys.argv[1:])) or 0) & 255)
line 65, in dispatch
remote: remote:     return _runcatch(req)
line 88, in _runcatch
remote: remote:     return _dispatch(req)
line 739, in _dispatch
remote: remote:     cmdpats, cmdoptions)
line 513, in runcommand
remote: remote:     ret = _runcommand(ui, options, cmd, d)
line 829, in _runcommand
remote: remote:     return checkargs()
line 800, in checkargs
remote: remote:     return cmdfunc()
line 736, in <lambda>
remote: remote:     d = lambda: util.checksignature(func)(ui, *args,
**cmdoptions)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/util.py",
line 475, in check
remote: remote:     return func(*args, **kwargs)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/commands.py",
line 5045, in serve
remote: remote:     s.serve_forever()
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/sshserver.py",
line 93, in serve_forever
remote: remote:     while self.serve_one():
line 111, in serve_one
remote: remote:     rsp = wireproto.dispatch(self.repo, self, cmd)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/wireproto.py",
line 349, in dispatch
remote: remote:     return func(repo, proto, *args)
line 588, in unbundle
remote: remote:     r = repo.addchangegroup(gen, 'serve', proto._client())
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/localrepo.py",
line 2176, in addchangegroup
remote: remote:     url=url, pending=p)
line 263, in hook
remote: remote:     return hook.hook(self.ui, self, name, throw, **args)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/hook.py",
line 173, in hook
remote: remote:     r = _pythonhook(ui, repo, name, hname, hookfn, args,
throw) or r
line 38, in _pythonhook
remote: remote:     obj = __import__(modname)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/mercurial/demandimport.py",
line 95, in _demandimport
remote: remote:     return _import(name, globals, locals, fromlist, level)
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/libbucket/hooks.py",
line 26, in <module>
remote: remote:     from bitbucket.apps.repo2.hooks import prehooks,
posthooks
bitbucket.org/current/bitbucket/apps/repo2/hooks.py", line 5, in <module>
remote: remote:     from django.contrib.auth.models import User
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/django/contrib/auth/models.py",
line 7, in <module>
remote: remote:     from django.db import models
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/django/db/__init__.py",
line 14, in <module>
remote: remote:     if not settings.DATABASES:
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/django/utils/functional.py",
line 276, in __getattr__
remote: remote:     self._setup()
bitbucket.org/2012-08-14/bitbucket/local/env/lib/python2.7/site-packages/django/conf/__init__.py",
line 42, in _setup
remote: remote:     self._wrapped = Settings(settings_module)
line 139, in __init__
remote: remote:     logging_config_func(self.LOGGING)
remote: remote:   File "/opt/python/2.7.3/lib/python2.7/logging/config.py",
line 777, in dictConfig
remote: remote:     dictConfigClass(config).configure()
line 575, in configure
remote: remote:     '%r: %s' % (name, e))
remote: remote: ValueError: Unable to configure handler 'backup': [Errno
13] Permission denied: '/opt/python/domains/
bitbucket.org/current/bitbucket/local/logs/backup.log'
remote: abort: unexpected response: empty string
remote: warning: changegroup hook exited with status 255
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120917/d53764c6/attachment.html>
