[petsc-dev] plans for testing examples?
Mon Sep 17 16:50:07 CDT 2012
On Mon, Sep 17, 2012 at 4:43 PM, Gerard Gorman <g.gorman at imperial.ac.uk>wrote:
> Will/Do these scripts return $? != 0, print "fail" or something else
> consistent upon failure?
Absolutely. I'll also make a way to associate actions with completion so
you could get your python module called.n
> I can appreciate you want the results outputted
> in some kind of database for interrogation (would be nice to see if
> commits improved/worsened code performance) but a consistent signal for
> test failure would make it easy to also integrate it with buildbot or
> other.
Would you prefer that my code runs the tests and reports completion status
to you (via Python callback which you can run shell command from if you
like) or would you rather query a list of all tests, then each one
individually?
> Let me know when it's ready for playing with and I'll hook it up with my
> local buildbot.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120917/e61f59ee/attachment.html>
