[petsc-dev] Runtime errors for spooles on BlueGene/Q
Hong Zhang hzhang at mcs.anl.gov
Sun Sep 9 11:10:32 CDT 2012
I
On Sun, Sep 9, 2012 at 11:06 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 9, 2012, at 11:00 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> > Yes, we should remove PETSc support for Spools and DSCPack.
> > Should we remove all relevant source codes?
>    Any source that would be dead code if you don't use Spools or DSCPack
> should be removed.
>    Barry
> It will always be there in the deleted part of the repository so it is
> never truly lost.
I'll do the removing.
Hong
> > Hong
> > On Sun, Sep 9, 2012 at 10:16 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 9, 2012, at 9:00 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>
> wrote:
> > >> We can apply this patch, but do you really find Spooles useful? It
> has not
> > >> been maintained in a long time.
> > > I think that the PETSc project has unofficially been maintaining
> > > Spooles.  If PETSc stops maintaining it, then it might be time to stop
> > > offering the download option for the project or at least deprecating
> > > it.
> >     I think it is time to remove PETSc support for Spools since it is
> not supported and appears to violate MPI standards that mater on some MPI
> systems.
> >     Barry
> > > A
> > > This message and its contents, including attachments are intended
> solely
> > > for the original recipient. If you are not the intended recipient or
> have
> > > received this message in error, please notify me immediately and delete
> > > this message from your computer system. Any unauthorized use or
> > > distribution is prohibited. Please consider the environment before
> printing
> > > this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120909/31cdbd4c/attachment.html>
