[petsc-dev] Runtime errors for spooles on BlueGene/Q
Jed Brown five9a2 at gmail.com
Sun Sep 9 08:00:19 CDT 2012
We can apply this patch, but do you really find Spooles useful? It has not
been maintained in a long time.
On Sep 9, 2012 8:46 AM, "Stefano Zampini" <stefano.zampini at gmail.com> wrote:
> Hi all,
> on BG/Q, I cannot use the current version of spooles when configuring
> petsc with download-spooles=1.
> Namely, I get runtime errors related on MPI buffers aliasing in
> MPI_Allgather calls.
> Aliasing is prohibited by the MPI standard as in Fortran standards.
> Attached please find some modified spooles' files which work on BG/Q.
> I only changed the files that use MPI_Allgather. I don't know if there are
> other aliasings inside the code.
> I tested them and now it works. No more runtime errors.
> Could you patch the PETSc version of spooles with these new files?
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120909/dd116a49/attachment.html>
