[petsc-dev] Workaround in MatTranspose_MPIAIJ does not work
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Oct 29 02:24:55 CDT 2012
you made a workaround for the MatTranspose problem with one-side
communications:
https://bitbucket.org/petsc/petsc-dev/changeset/43e28ef1a420
My code now crashes on MatTranspose in line 2147 of
src/mat/impls/aij/mpi/mpiaij.c, as the matrix object is not created but
MatSetOption is executed on this matrix.
Best regards,
Thomas
