[petsc-dev] [petsc-users] Problem of installing PETS with MPI on windows 8 64 bit
Travis Austin austin at txcorp.com
Sat Oct 20 14:31:28 CDT 2012
I recently encountered this problem and removed the --with-mpi-include and --with-mpi-lib lines
on the configure line and added --with-mpi=1.  Then I let the PETSc build system find the include
files and library files and it did so successfully.  After digging into MPI.py I can see that they look
in the right directories (for this particular specification of the msmpi libraries) by default.
It may not be the preferred way but it is another option.
Travis
>> ./configure --with-cc="win32fe cl" --with-fc=0
>> --download-c-blas-lapack=1 --with-mpi-include="/cygdrive/c/Program
>> Files/Microsoft HPC Pack 2008 SDK/Include"
>> --with-mpi-lib="/cygdrive/c/Program Files/Microsoft HPC Pack 2008
>> SDK/Lib/amd64/msmpi.lib"
>> We get the following complain, while these two directories mentioned
>> by the error messages are actually there,
>>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for detail
>> s):
>> --with-mpi-lib=['/cygdrive/c/Program', 'Files/Microsoft', 'HPC', 'Pack', '2008',
>> 'SDK/Lib/amd64/msmpi.lib'] and
>> --with-mpi-include=['/cygdrive/c/Program Files/Microsoft HPC Pack 2008 SDK/Inclu
>> de'] did not work
>> Any of you have some idea how to fix it?
>> Thanks and best regards,
>> Bin
>> Bin Shen
>> Dept. of Computer Science, Purdue University
>> West Lafayette, IN., US
>> http://www.cs.purdue.edu/homes/bshen/
