[petsc-dev] [petsc-maint #135017] Re: petsc-dev/buildsystem is broken on OS X.6+openmpi-nofortran
Satish Balay petsc-maint at mcs.anl.gov
Sun Oct 7 11:29:06 CDT 2012
Hm - nightlybuilds use --download-mpich=1 - but I don't see this error
on OSX build.
wrt binsection - the following worked - the last time I tried.
http://www.mcs.anl.gov/petsc/documentation/faq.html#bisect
Satish
On Sun, 7 Oct 2012, Aron Ahmadia wrote:
> reproduced with --download-mpich=1
> how the heck do you guys bisect with two independent repos?
> A
> On Sun, Oct 7, 2012 at 6:28 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
> > I'm able to reproduce with shared libraries enabled and disabled.  Your
> > nightly logs aren't indicating failures as far as I can tell.
> > changeset:   24541:729963bc657c
> > tag:         tip
> > user:        Stefano Zampini <stefano.zampini at gmail.com>
> > date:        Sat Oct 06 13:39:31 2012 +0200
> > summary:     Rearranged some deallocations when building FETIDP mat.
> > (same failure with 2 processes), I'm looking into whether any of the
> > specific configure options (python/shared libraries) triggers the failure.
> > ~/s/petsc ❯❯❯ make PETSC_DIR=/Users/aron/sandbox/petsc
> > PETSC_ARCH=arch-darwin-c-debug test
> > Running test examples to verify correct installation
> > Using PETSC_DIR=/Users/aron/sandbox/petsc and
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
> > process
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > [peregrine:31992] *** Process received signal ***
> > [peregrine:31992] Signal: Segmentation fault (11)
> > [peregrine:31992] Signal code: Address not mapped (1)
> > [peregrine:31992] Failing at address: 0x440000b0
> > [peregrine:31992] [ 0] 2   libSystem.B.dylib
> > 0x00007fff846391ba _sigtramp + 26
> > [peregrine:31992] [ 1] 3   ???
> > 0x0000000101434fd0 0x0 + 4316155856
> > [peregrine:31992] [ 2] 4   libpetsc.dylib
> >  0x0000000100118456 PetscInitialize + 1424
> > [peregrine:31992] [ 3] 5   ex19
> >  0x000000010000110f main + 43
> > [peregrine:31992] [ 4] 6   ex19
> >  0x00000001000010dc start + 52
> > [peregrine:31992] [ 5] 7   ???
> > 0x0000000000000007 0x0 + 7
> > [peregrine:31992] *** End of error message ***
> > mpiexec noticed that job rank 0 with PID 31992 on node peregrine.local
> > exited on signal 11 (Segmentation fault).
