[petsc-dev] Matrix Free Conjugate Gradient
Fri Nov 30 23:37:22 CST 2012
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatShellSetOperation.html
Note that without an assembled matrix, you'll generally need to write your
own preconditioner, which you can do using PCShell.
On Fri, Nov 30, 2012 at 11:24 PM, Hesameddin Ilatikhameneh <
hilatikh at purdue.edu> wrote:
> Hello,
> We have a very large system (100M variables) which we want to minimize its
> energy. We are using Petsc extensively for matrix operations.
> I know that it is theoretically possible to use conjugate gradient method
> without storing Jacobian matrix (which is very huge in this case) since the
> conjugate gradient needs Jacobian times a vector not Jacobian itself.
> I read your manual about matrix free methods but I couldn't find where I
> can determine that function to Jacobian times a vector.
> I appreciate your help.
> Thanks
> Hesam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121130/a78d963d/attachment.html>
