[petsc-dev] Matt: what do to with src/snes/examples/tutorials/ex8.c ?
Sat Nov 24 12:03:56 CST 2012
On Nov 24, 2012, at 10:27 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Nov 24, 2012 at 12:00 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Matt,
>>   src/snes/examples/tutorials/ex8.c   apparently went untested for a long while.
>>   Recently I added it to the nightly tests. It does not work because it improperly did not call MatAssemblyBegin/End() collectively (in trying to do boundary conditions).
>>   It appears to be some ancient attempt at doing finite elements for a simple problem (yet uses MatSetValuesStencil?)
>>   It needs to be fixed up or completely removed from the source code?   I say just remove it all. What do you think?
> Yes, remove it. We are going to do a different version with the
> support today (DM + Section/IS++).
  Done
>   Matt
>>   Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
