[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
Fri Nov 16 14:32:19 CST 2012
Do you want to have the repo name as 'buildsystem' or
'buildsystem-dev'?
note: reclones shouldn't be need for such renames [or url changes] -
but one is free to do that if they want to..
Satish
On Fri, 16 Nov 2012, Barry Smith wrote:
>   I am not advocating fixing all capitalizations at this time, just BuildSystems.
>   Plus we should tell everyone to completely reclone anyways.
>    Keeping the in consist BuildSystem just to prevent a small number of temporary hiccups is not a good idea. We're writing PETSc not lapack.
>    Barry
> >> On Nov 16, 2012, at 11:14 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> I'm in the process of migrating repos from petsc.cs.iit.edu to
> >>> bitbucket.org, and have to resolve a few organization issues.
> >>> Restrictions.
> >>> - all repos should be lowercase
> >>> - no subdir organization possible [like http://petsc.cs.iit.edu/petsc/externalpackages/]
> >>> 1. Since we are forced to change reponame from 'BuildSystem' to
> >>> 'buildsystem' - I'd like to take this opportunity to change it to
> >>> 'buildsystem-dev' to be consistent with petsc-dev. i.e instructions
> >>> will be:
> >>> hg clone https://bitbucket.org/petsc/petsc-dev
> >>> hg clone https://bitbucket.org/petsc/buildsystem-dev petsc-dev/config/BuildSystem
> >>> or
> >>> hg clone https://bitbucket.org/petsc/petsc-release
> >>> hg clone https://bitbucket.org/petsc/buildsystem-release petsc-release/config/BuildSystem
> >>> and current clones would need updates to .hg/hgrc only.
> >>> one alternative was to change the path in source to
> >>> petsc-dev/config/buildsystem but it will cause some breakage and other
> >>> inconsistencies in source file naming scheming - so I'm against that
> >>   What breakage. I really don't like having caps in one place and small letters in another. Horrible inconsistency
> > I guess one can anticipate all issues and make configure deal with
> > them. [with autofix - or with an error message]. The couple of
> > issues I was thinking off:
> > - different organization between petsc-release and buildsystem confusing
> > users.
> > - configure might automatically create a new 'buildsystem' clone - when
> > the user might still have BuildSystem - and attempt to make changes there.
> > - bisection might need manual tweaking if if needs to go back and
> >  forth over this changepoint [from BuildSystem to buildsystem]
> > Also we won't have consistant naming of 'reop' to 'file' anyway. So I
> > see not much motivation to preserve the 'lowercase' part of the
> > attribute.
> > i.e buildsystem-dev -> buildsystem
> >    buildsystem-release -> buildsystem
> > Also with this rename - lot of sourcefiles/dirs have to be renamed
> > [for a consistant lowercase naming scheme] - loosing annotations in
> > mercurial history [perhaps mercurial should handle this automatically
> > - but I haven't checked it in depth].
> > Satish
> >>    Barry
> >>> another alternative is to use 'petsc', 'buildsystem', 'petsc-release',
> >>> 'buildsystem-release' [but we have too much baggage referring to
> >>> petsc-dev, with a mailing list etc reusing this name]
> >>> 2. I plan to reorganize external package repos [that we might have
> >>> patches for] with a pkg prefix.
> >>> i.e
> >>> http://petsc.cs.iit.edu/petsc/externalpackages/metis-5.0.2
> >>> http://petsc.cs.iit.edu/petsc/externalpackages/parmetis-4.0.2
> >>> to:
> >>> https://bitbucket.org/petsc/pkg-metis-5.0.2
> >>> https://bitbucket.org/petsc/pkg-parmetis-4.0.2
> >>> etc..
> >>> 3. Are AMS, ctetgen, win32fe special packages and be listed at toplevel?
> >>> currently ctetgen is listed under 'externalpackages'. Should it be at toplevel?
> >>> i.e
> >>> https://bitbucket.org/petsc/win32fe-dev
> >>> https://bitbucket.org/petsc/ams-dev
> >>> https://bitbucket.org/petsc/ctetgen-dev
> >>> Any thoughts?
> >>> thanks,
> >>> Satish
