[petsc-dev] TSMonitorSPEigCtxCreate calls KSPSetFromOptions
Sat Nov 10 11:33:15 CST 2012
which eventually calls PetscOptionsEnd, masking all subsequent options from
the TS output. Choices:
1. circumvent the limitation, moving the call outside the TS options
2. make PetscOptionsBegin() behave like PetscOptionsHead() when called
inside a currently active options section
others?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121110/5588e375/attachment.html>
