[petsc-dev] Fwd: [mumps-dev] support for distributed right-hand vectors?
Sat Nov 10 09:08:55 CST 2012
On Sat, 10 Nov 2012, Alexander Grayver wrote:
> /*To petsc developers:* /are there plans to update PaStiX supplied with PETSc?
> The current version is 5.2 from 2012-06-08 and PETSc-3.3-p3 uses 5.1.8 from
> 2011-02-23.
> Here is changelog:
> https://gforge.inria.fr/frs/shownotes.php?group_id=186&release_id=7096
Usually we update petsc-dev with newer releases of externalpackages.
The build appears to go through fine - so I pushed this to petsc-dev
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/b7bdde2395c4
You can try the following with petsc-3.3:
--download-pastix=https://gforge.inria.fr/frs/download.php/30920/pastix_release_3725.tar.bz2
Satish
