[petsc-dev] http://morphmpi.sourceforge.net
Fri Nov 9 20:30:39 CST 2012
Last updated in 2009.
*To use MorphMPI in your application:*
*First all references to MPI-variables and MPI-functions in your
application need to be changed to refer to MorphMPI-variables and
MorphMPI-functions (e.g. MPI_Send becomes MorphMPI_Send. This can easily be
done by executing the morph.sh script on every header and source file.*
*Note: This step could actually be circumvented by another layer containing
MPI-conforming functions that would call the MorphMPI functions that on
their turn the 3rd party MPI-functions.*
*Next you need to compile your application with the morphmpi.h header in
the include-path.*
*When linking your application you first need to link with the MorphMPI
library and next with the library of the MPI implementation for which
MorphMPI was configured.
I don't know why they don't use the PMPI interface to avoid the renaming
insanity.
On Fri, Nov 9, 2012 at 7:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121109/b7bcac37/attachment.html>
